Toymods » Tech & Conversions » CT20b/CT26 flanges the same?
CT20b/CT26 flanges the same? Wed, 10 September 2003 09:22 Go to next message
Well are they???? Very Happy
ChuckLandwehr
Re: CT20b/CT26 flanges the same? Wed, 10 September 2003 12:01 Go to previous messageGo to next message
No, just checked em both out!
regards Chuck.
Re: CT20b/CT26 flanges the same? Wed, 10 September 2003 12:11 Go to previous messageGo to next message
DOH Evil or Very Mad How much difference is there?
ChuckLandwehr
Re: CT20b/CT26 flanges the same? Wed, 10 September 2003 12:23 Go to previous messageGo to next message
You could possibly make up a flange adapter, 'cause the studs of the CT20 would fit within the flange of a CT26. It really depends on your application, ie, CT20 to CT26 manifold or vice versa. if you want specific dimensions just ask!
regards Chuck.
Re: CT20b/CT26 flanges the same? Wed, 10 September 2003 12:29 Go to previous messageGo to next message
The reason I ask is because I happen to know someone who has been making some turbo manifolds and he will be making one for me! But he has been making them to suit the CT26 whereas my turbo is a CT20B!
Maybe I should just send the turbo gasket and be done with it?
flupstar
Re: CT20b/CT26 flanges the same? Wed, 10 September 2003 12:39 Go to previous messageGo to next message
depends. there are two common CT26s.. the 7M supra job, single entry round flange..
and the 3sgte (mr2, gt4) job.. which has the identical twin entry flange as the CT20b from the same engine
so.. it depends what version of the CT26 the manifold is made for
-Tristan
Re: CT20b/CT26 flanges the same? Wed, 10 September 2003 12:42 Go to previous messageGo to next message
So if the CT26 the manifold was for was from a 3S-GTE the CT20B would fit?
flupstar
Re: CT20b/CT26 flanges the same? Wed, 10 September 2003 13:19 Go to previous messageGo to next message
bingo. yes thats correct.
eg. US MR2 crowd is very familiar with replacing the gen II 3sgte's CT26 with the gen III's CT20b as it is a direct bolt on - flanges are the same.
however, if you're talking about 3sgte's... a gen II manifold will not bolt to a gen III (ST205) head. the stud pattern and ports are all different.
if the manifold is definately designed for your head and a CT26 turbo flange then you're in luck!
-Tristan
JustenGT4
Re: CT20b/CT26 flanges the same? Wed, 17 September 2003 03:30 Go to previous message
The CT26 from the Gen II 3SGTE in both the MR2 and GT4 has the same exhaust manifold flange as the CT20B. The dump pipe flange on the CT20B has one extra stud but you can still interchange dump pipes. There can be some wastegate clearance issues though so check that the wastegate still opens fully once the dump pipe is fitted.
I have run a CT26 turbine housing on the Gen III 205 engine no probs.
Previous Topic:20V INTO SX SECA
Next Topic:Water Sprayers on st185cs inter cooler radiator.
Current Time: Sat Nov 21 13:38:35 UTC 2026
Total time taken to generate the page: 0.0057461261749268 seconds
