Toymods » Tech & Conversions » 1JZGTE VVTi Details
deesonet
Toowoomba
1JZGTE VVTi Details Wed, 10 September 2003 11:06 Go to next message
Have just purchased 1JZGTE VVTi for my next conversion (Lexus IS200). DOes anyone know of any good sites with technical information about the Toyota VVTi systems.
wilbo666
Re: 1JZGTE VVTi Details Wed, 10 September 2003 12:35 Go to previous messageGo to next message
Bills site has lots of good stuff Shocked Very Happy
Not a 1J but its a start, hope it helps.
bills site
ChuckLandwehr
Re: 1JZGTE VVTi Details Wed, 10 September 2003 12:43 Go to previous messageGo to next message
Hi Mate, I have a VVTi 1JZ-GTE, and there is nothing out there except for basic info from sales brochures for MKII's etc.
Cam belts are available through Toyota!
Turbo from what I have been able to discern is a CT20B.
Compression Ratio 9:1, whoo hoo.
VVTi, looks at a heap of different parameters for its operation, so a factory computer would be the best bet to get max efficiency out of the VVTi. I personally would use an interceptor (Unichip Apexi) to modify fuel and ignition, if you're after more KW's
Most aftermarket computers do not have the finness to accurately control the VVTi through its entire operating spectrum.
2JZ-GE flywheels WILL bolt up to the 1J.
Injectors are NOT side feed, which opens up a heap of scope for cheap bigger injectors (eg. 13B Rotary).
Ray Hall Turbocharging has recently completed a 2JZ-GTE conversion into an IS200. Check out ZOOM or HPI for his story and contact details. Give me a yell if you need more.
regards Chuck
Soarer
Wollongong
Re: 1JZGTE VVTi Details Thu, 11 September 2003 09:09 Go to previous messageGo to next message
I thought the 1JZ VVTi used a CT15B turbo... could be wrong though. Very little info about those engines around.
deesonet
Toowoomba
Re: 1JZGTE VVTi Details Thu, 11 September 2003 10:36 Go to previous messageGo to next message
Thanks guys
That's a start to my learning this beast.
Manny
Re: 1JZGTE VVTi Details Thu, 11 September 2003 12:40 Go to previous messageGo to next message
CT15b is the one
Try this in Babelfish for a few more details and turbocharger specs - expect to toss the turbo out earlier than a TT 1JZ-GTE as it's apparently more limited in it's capability and is still ceramic
http://www5c.biglobe.ne.jp/~a14865/chaser/1jz_gte. htm
deesonet
Toowoomba
Re: 1JZGTE VVTi Details Sat, 20 September 2003 10:13 Go to previous messageGo to next message
Chuck
What is your VVTi fitted into?
I have my engine now and have unpacked it. There is a lot of differences between it and the normal 1jzgte motor. I have one of them in the garage as well so can compare them directly to each other.
sideshow
Re: 1JZGTE VVTi Details Sat, 20 September 2003 10:23 Go to previous messageGo to next message
what are the pin configuration on the ecu for the 1j vvti
deesonet
Toowoomba
Re: 1JZGTE VVTi Details Sat, 20 September 2003 11:33 Go to previous messageGo to next message
That's what I am trying to find a diagram for as well.
Apart from the VVTi wiring there are more pins than the previous 1JZ I wired up.
sideshow
Re: 1JZGTE VVTi Details Sat, 20 September 2003 11:44 Go to previous messageGo to next message
is there 4 big ecu plugs
each plug has 4 rows of wires
deesonet
Toowoomba
Re: 1JZGTE VVTi Details Sat, 20 September 2003 11:49 Go to previous messageGo to next message
Yes, four x four row plugs.
saa_
Re: 1JZGTE VVTi Details Sun, 21 September 2003 03:34 Go to previous messageGo to next message
How much did it set you back if you don't mind me asking?
And from where?
Half cut? or just engine and box?
Truzeno
Hunter Valley
Re: 1JZGTE VVTi Details Sun, 21 September 2003 03:51 Go to previous messageGo to next message
Just couple questions lol.
What does the on woit the VVT come out of.
And does any type of variable cam/valve timing such as VVT or VTEC make it harder when modding to high HP numbers?... just something I heard....
Soarer
Wollongong
Re: 1JZGTE VVTi Details Sun, 21 September 2003 04:19 Go to previous messageGo to next message
VVTi 1JZ-GTE comes out of the 1996+ Soarer and I believe Mark II and Chaser.
I have also heard that the VVTi makes it harder to get more power of later in the game, and people seem to just disable it to get around the complexity. Only what I've heard though.
deesonet
Toowoomba
Re: 1JZGTE VVTi Details Sun, 21 September 2003 04:53 Go to previous messageGo to next message
Paid $1600 incl freight to Toowoomba.
Yes, they are a bit tricky when chasing big HP. I won't be modding much as the standard power is almost double what it is replacing (1G-FE VVTi @ 114kw). Perhaps just a boost lift to about 10-12psi, that's all.
ChuckLandwehr
Re: 1JZGTE VVTi Details Mon, 22 September 2003 11:36 Go to previous messageGo to next message
Graham, my 1J came from a 1999 Chaser.
regards Chuck.
Celia-Sue
Re: 1JZGTE VVTi Details Tue, 23 September 2003 02:05 Go to previous message
FWIW,
C-Red in Perth are selling JZX100 half-cut for $4,500. Wish it had been around 6 months ago. Sad
Justin
JZA61 hybrid monster
Previous Topic:3T Upgrades
Next Topic:4runner Service Diesel Turbo
Current Time: Fri Nov 20 11:13:24 UTC 2026
Total time taken to generate the page: 0.006166934967041 seconds
