Toymods » Tech & Conversions » RPM Fluctuates Why ?
dispatcher
Malaysia,Kuala Lumpur
RPM Fluctuates Why ? Wed, 10 September 2003 17:23 Go to next message
MY 1G TT tend to fluctuate the RPM , with or without aircond and especially after a hard run. How can i solve this ?..Is there like that thingy which controls the vacumm for the throttle to idle the aircon when it's off/on, what's it called FICD ??...
Or is the 1G fully automated,mind u this is a minor fluctuation.
IRA11Y
Club Member
Re: RPM Fluctuates Why ? Wed, 10 September 2003 19:44 Go to previous messageGo to next message
it may be the TPS needs resetting
Chris Davey
sunny coast, qld
Re: RPM Fluctuates Why ? Wed, 10 September 2003 22:35 Go to previous messageGo to next message
mine does the same. i thought i had an air leak in the intake somwhere.
punkdefender
Dandenong/VIC
Re: RPM Fluctuates Why ? Thu, 11 September 2003 04:08 Go to previous messageGo to next message
mine does that aswell also after a long drive on the freeway idle rpm goes high, normally 700 rpm and it goes up to 800 rpm...
Has anybody else noticed this with there 1G?
onejayzed
Re: RPM Fluctuates Why ? Thu, 11 September 2003 04:52 Go to previous messageGo to next message
check your throttle body linkages aren't sticky with grime.
check for air leaks that push out after hard driving.
even check your o2 sensor isn't dirty, or 'fouling' because it runs a bit rich after hard driving.
sbyder
Ipswich QLD
Re: RPM Fluctuates Why ? Thu, 11 September 2003 07:10 Go to previous messageGo to next message
same problem Sad
I will check for the above mentioned and see what happens Smile
dispatcher
Re: RPM Fluctuates Why ? Thu, 11 September 2003 15:35 Go to previous messageGo to next message
Guys, heads up - i had the previous day fooled around with the TPS, today again i tried and found out that it actually also affects the idle speed.(interesting).
So i set TPS in original position,pulled ECU fuse and reset the whole thing, NOW not so much a fluctuation, hardly notice it. Could be air leakage somewhere,
So will have to check out the vac/throttle lines.
Chris Davey
sunny coast, qld
Re: RPM Fluctuates Why ? Thu, 11 September 2003 15:56 Go to previous messageGo to next message
sorry to ask such a silly question, but what exactly does the TPS look like? I have never really played around with my 1g Smile
gold28
Madrid - Spain
Re: RPM Fluctuates Why ? Fri, 12 September 2003 00:17 Go to previous messageGo to next message
onejayzed wrote on Thu, 11 September 2003 14:52
so thats why mine runs rich all the time Rolling Eyes Very Happy
dispatcher
Re: RPM Fluctuates Why ? Sat, 13 September 2003 15:32 Go to previous messageGo to next message
Guys, just thought you all would like to know, today pulled apart Throttle Body, and my suspicions were confirmed, GASKET !! that sits on the face of the T/body, it had all the vacumm breather holes sealed. I know it sounds far-fetched, but this is the second time i've encountered it.
First time old 1G-GEU engine which i bought for my Cress GX60, it was second-hand, had pick up and idling probs,same with the 1G-TT..a new gasket made with breather holes, now it's fine.
No harm in checking T/body just to be sure..
sbyder
Ipswich QLD
Re: RPM Fluctuates Why ? Sun, 14 September 2003 03:06 Go to previous message
would it be possible for you to get a pic of what/where the gasket is, as i'm not sure which one your talking about.
Ben
Previous Topic:Gearbox swap overs.
Next Topic:TrueTrac LSD into MA61
Current Time: Thu Oct 29 09:50:09 UTC 2026
Total time taken to generate the page: 0.079666137695312 seconds
