Toymods » Tech & Conversions » AE71 EFI fuel setup - surge tanks etc.
AE71 EFI fuel setup - surge tanks etc. Thu, 11 September 2003 02:37 Go to next message
Ok, i have never really had to do this before, so i am not 100% certain on EXACTLY what should be done.
The fuel setup to be thus far is:
# standard tank
# AUDI/PORCHSE Bosch 921 high pressure pump
# lift pump (not sure on specs)
# surge tank
# standard fuel lines
Now the way i think i'm supposed to set this up is:
# From fuel tank to carby fuel filter
# carby fuel filter to lift pump
# lift pump to surge tank
# surge tank to EFI pump
# EFI pump to fuel rail (along standard feed line)
# Fuel rail to return line
# return line as standard back to the tank.
HOWEVER!!
Some people have mentioned that the lift pump won't flow enough to keep the surge tank full or something like that, so the surge tank needs to have a return back to the tank, or something like this?
I have a 3rd (currently blocked) outlet on the surge tank which i can use as a return, so i just want to know what i should be doing. Thanks Smiley =
Re: AE71 EFI fuel setup - surge tanks etc. Thu, 11 September 2003 02:45 Go to previous messageGo to next message
Most people run the return line from the fuel rail back to the surge tank, and the surge tank overflow goes back to the fuel tank.
rob_RA40
c'town, NSW
Re: AE71 EFI fuel setup - surge tanks etc. Thu, 11 September 2003 02:49 Go to previous messageGo to next message
hope this isnt too confusing, i drew this for my tech article, follow the arrows...
http://www4.tpgi.com.au/users/loats/technical/ra40/images/1ggeconversion/FuelSystem.jpg
[Updated on: Thu, 11 September 2003 02:49]
Re: AE71 EFI fuel setup - surge tanks etc. Thu, 11 September 2003 02:52 Go to previous messageGo to next message
That would mean there would be 4 taps on the surge tank? or three? Mine has three, but i can get another one....
Karl be confused, he is stupid an knows only of carbushitters Smile
rob_RA40
c'town, NSW
Re: AE71 EFI fuel setup - surge tanks etc. Thu, 11 September 2003 02:55 Go to previous messageGo to next message
if u set it up the same as the diagram u will need 4
if u run the return from the fuel rail back to the main fuel tank then u only need 3, but u have to make sure the lift pump can flow enough to always keep the surge tank topped up.
Re: AE71 EFI fuel setup - surge tanks etc. Thu, 11 September 2003 06:04 Go to previous messageGo to next message
I agree with Robs method..
Thats what i've done on mine.. 4 outlets on the surge tank with return line coming back to the surge tank. Never have to worry about it running dry then!
shinybluesteel
melbourne
Re: AE71 EFI fuel setup - surge tanks etc. Thu, 11 September 2003 06:40 Go to previous messageGo to next message
there isnt anything wrong with running the return line back to the main tank, just that your lifter pump has to supply much more fuel than the engine is using, wheras with the return going to the surge tank, the lifter pump only has to supply as much fuel as the engine as using. probly be easier to put another fitting in the surge tank, or just use an internal surge tank and a swimmer pump, but this might be more expensive.
pm me if you want to know the king design for an internal surge tank.
IRA11Y
Club Member
Re: AE71 EFI fuel setup - surge tanks etc. Thu, 11 September 2003 06:45 Go to previous messageGo to next message
My advice is to check the new ADR's on fuel delivery systems as i believe there have been some changes to the regulations recently. Some of these changes may make the surge tank unfeasable, or a hassle with engineering.
for your setup Karl if you want the cheap and reliable method....
obtain a sprinter fuel tank, there seem to be a few that have crashed lately so there should be plenty available, if you cant find one let me know as i may know of one or two laying around.
next buy a AE82 fuel pump and bracket from P&PL there are a couple sitting there as I write this.
weld a small lengthening section to the bracket ( I can help you with that) fit it to the sprinter tank and take the neck off the sprinter tank and replace youre stock tank with the sprinter one.
replace all the rubber lines and clamps with efi type and youre in bussines Smile
shinybluesteel
melbourne
Re: AE71 EFI fuel setup - surge tanks etc. Thu, 11 September 2003 12:54 Go to previous messageGo to next message
IRAllY, do you mean use a carby sprinter fuel tank? do these cope ok without baffling for EFI?
my plan (for 4AGE into AE86) is to use a "whatever is cheap" swimmer pump and an internal surge tank, is it even simpler than this?
Re: AE71 EFI fuel setup - surge tanks etc. Thu, 11 September 2003 13:15 Go to previous messageGo to next message
Ah, things to think about, i have.
IRA11Y
Club Member
Re: AE71 EFI fuel setup - surge tanks etc. Thu, 11 September 2003 19:48 Go to previous message
yes you can use the standard tank, if you can get hold of the efi tank even better but they are pretty hard to come by and not all that much better in any case as they arent designed for hard cornering.
the trade off with the above mod is that you really need to keep your tank at least 25% full when giving the car a good flogging or you will get surge when making tight right hand turns (fuel runs to the left of the tank away from pickup) I do have a couple of ideas on how to stop this problem but havent trialed them yet. for normal driving you can still get down to almost empty before you start to feel surge if you set the height of the pump up correctly.
Previous Topic:18RG Exhaust system components location - Which is more restrictive?
Next Topic:1gtte tps setting...
Current Time: Thu Oct 15 22:53:44 UTC 2026
Total time taken to generate the page: 0.0223228931427 seconds
