Toymods » Tech & Conversions » MA61 emmission system..
boudan
MA61 emmission system.. Thu, 11 September 2003 11:35 Go to next message
What is / are the impacts of not running the emmission system ?
apart from the obivious higher emmission output through the exhaust ....
any negative impacts of performace / effieceny ??
BlackSupra
Re: MA61 emmission system.. Thu, 11 September 2003 11:42 Go to previous messageGo to next message
EPA fines
Defects
Less recirculating unburnt gases should decrease the intake charge temps (minor degree id say)
There will be no reduction in octane levels due to no oil blow by from the crank case (assuming you are doing a catch can setup)
And i have no idea how the carbon canister works on these things Smile
ed_ma61
Lost in the K hole
Re: MA61 emmission system.. Thu, 11 September 2003 14:28 Go to previous messageGo to next message
BlackSupra wrote on Thu, 11 September 2003 21:42
EPA fines Defects
not if youre handy and just plug the lines with ball bearings, and put it all back together stock looking Smile
youre talking about the EGR? egr actually decreases combustion temperatures as it is considered 'dead space' in the chamber. you disconnect it, comb temps will go up (along with power) but your emissions will also go up
you can happily leave the carbon canister connected as it really does bugger all to the intake, but does recirculate and filter tank gas (i think)
ed
Re: MA61 emmission system.. Fri, 12 September 2003 01:36 Go to previous message
ed_ma61 wrote on Fri, 12 September 2003 00:28
Actually a correctly functioning EGR system will disable itself at WOT, thus there should be no effect on peak power.
Previous Topic:dodgy flatspot
Next Topic:18RG Exhaust system components location - Which is more restrictive?
Current Time: Fri Oct 16 03:55:48 UTC 2026
Total time taken to generate the page: 0.094779968261719 seconds
