Toymods » Tech & Conversions » 4A-GZE pistons, where to get them
ajwiseman
Memphis, Tennessee
4A-GZE pistons, where to get them Thu, 11 September 2003 15:04 Go to next message
Just screwed up a set of Levin pistons due to a slight detination problem. If anyone has a set of the JDM 8.9:1 pistons that are not collapsted, please let me know. I also have some 4A-GZE parts such as a few intakes, superchasger, etc. if someone wants to trade. Thanks guys!
MODERATOR EDIT: changed title to inform the community Smile
[Updated on: Fri, 12 September 2003 09:40] by Moderator
Re: WTB: 4A-GZE pistons Fri, 12 September 2003 09:38 Go to previous messageGo to next message
Again for those that have missed me saying this almost for the 50th time.... Very Happy (being silly here!)
4A-GZE 8.9:1 factory forged & ceramic coated pistons as used in the latest model 4A-GZE engine are available from TOYOTA for a megre cost of ~$400!!
They are also available in slightly overbore sizes.
For part no.s, search the FAQ section of www.twincam.org
GZE-STYLE
Camden
Re: WTB: 4A-GZE pistons Fri, 12 September 2003 10:39 Go to previous messageGo to next message
Though when i rang up Toyota they said they didnt sell them and advised me to goto an engine importer Rolling Eyes
TA22-3SGTE
MACKAY
Re: 4A-GZE pistons, where to get them Fri, 12 September 2003 12:16 Go to previous messageGo to next message
( Rocket ) sell forged pistons for the 4AGZE , 3SGTE and 7MGTE also you can give ( Precision engine parts )a call as they also make forged pistons.
I just bought a set of 3SGTE pistons from TOYOTA for $372.00 .
Trevor
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: 4A-GZE pistons, where to get them Fri, 12 September 2003 15:01 Go to previous messageGo to next message
Yeah, I just got some new 4A-GZE pistons from Castle Hill Toyota, I ended up paying just $340 for the set.
Part no. 13103-16131
But that's for .020", or 0.50mm as Toyota so rightly put it, oversize pistons.
Grega
melbourne.victoria.austra...
Re: 4A-GZE pistons, where to get them Fri, 12 September 2003 22:37 Go to previous messageGo to next message
when you think of it, thats pretty darn cheap for a set of forged pistons...
BigWorm
Turramurra, Sydney.
Re: 4A-GZE pistons, where to get them Sat, 13 September 2003 00:31 Go to previous messageGo to next message
And ceramic coated. Looking at my new ones (I'll put up some pics eventually) they look like they have 2 types of ceramic coating, there's a dark coat on the crown of the piston, which comes down over the first ring land, then there's a shiny section of uncoated piston just over the second piston ring gap, then from the second ring land down it looks to be coated in a light grey coating. So there's 3 diferent colours, dark grey coated, shiny uncoated metal & then light grey coated.
Just out of interest.....
Twinky
N.S.W
Re: 4A-GZE pistons, where to get them Sat, 13 September 2003 03:00 Go to previous messageGo to next message
http://pub131.ezboard.com/ffwdtoyotafrm24.showMess age?topicID=57.topic
Very Happy Very Happy
Twinky
N.S.W
Re: 4A-GZE pistons, where to get them Sat, 13 September 2003 03:17 Go to previous messageGo to next message
Ask Tin_Can off these forums he will be able to help you out with anything Toyota, mobile is 0421820394
TE72_Turbo
Re: 4A-GZE pistons, where to get them Sat, 13 September 2003 06:47 Go to previous messageGo to next message
joel
Is that part number for 8:1 or 8.9:1 compression pistons?
Phil
Grega
Re: 4A-GZE pistons, where to get them Sat, 13 September 2003 09:20 Go to previous messageGo to next message
8.9:1 comp....late model GZE
twincam_ke20
Castlemaine Vic
Re: 4A-GZE pistons, where to get them Sat, 13 September 2003 11:39 Go to previous messageGo to next message
are all GZE pistons inter-changerable with each model 4agze? or no?
Grega
Re: 4A-GZE pistons, where to get them Sat, 13 September 2003 22:18 Go to previous messageGo to next message
from what i understand yes, they should be interchangable.
wondering how much PSI people are running with the 8.9:1 comp pistons....thats fairly high comp when you think about for turbocharging...
TE72_Turbo
Re: 4A-GZE pistons, where to get them Sun, 14 September 2003 04:07 Go to previous messageGo to next message
bugger. I'm still trying to find the part number for the 8.0:1 pistons.
I run the 8.9:1 GZE pistons at the moment, with 20psi of boost. I would like to build an engine with the lower compression to try and squeeze some more timing into it.
Phil
Sprinta
Re: 4A-GZE pistons, where to get them Sun, 14 September 2003 05:23 Go to previous messageGo to next message
Yeah 8.9 is bulk compression for a forced induction motor but it seems to hold together from what ive heard.
TE72_Turbo: How does it go with 20psi? Im going to be changing to map gze motor real soon with a hksgt2530 hopefully whacked on it with about 20psi.. hope itll hold together.
TE72_Turbo
Re: 4A-GZE pistons, where to get them Sun, 14 September 2003 11:02 Go to previous messageGo to next message
It'll hold together no worries, despite having high compression, the GE/GZE's seem to have a really good combustion chamber design in the head, which is not prone to detonation. Mine happily has 18 degrees of timing at 20psi (normal 98 octane pump fuel). Try doing that to a T series engine with compression only in the 7's, and it will detonate its head off due to their inferior head design.
I'd still like the 8.0:1 pistons to squeeze some more out of it though, hence searching for the part # Smile
BTW: Where did you get your HKS turbo? Was it new? They are hell expensive to purchase, i've been looking at one to upgrade lately Crying or Very Sad
Re: 4A-GZE pistons, where to get them Sun, 14 September 2003 11:38 Go to previous messageGo to next message
Hey dude, had a look in the EPC. The AW11 with 4AGZE had 8.0:1 right?
13101-16060 is the original part number, and this appears to be substituted with 13101-16100.
This last part number appears to come in standard and oversize 0.5mm. The part #'s appear to be the same for the standard and oversize which is weird.
Hope that helps.
TE72_Turbo
Re: 4A-GZE pistons, where to get them Sun, 14 September 2003 12:02 Go to previous messageGo to next message
thanks for that. Much appreciated Very Happy and yes, the AW11 is 8.0:1
Where can I get me a copy of this EPC??
Phil
Re: 4A-GZE pistons, where to get them Sun, 14 September 2003 12:05 Go to previous messageGo to next message
Search the forums, its on the net somewhere.
Sprinta
Re: 4A-GZE pistons, where to get them Sun, 14 September 2003 15:46 Go to previous messageGo to next message
Sweet sounds good, should be fun hehe..
I havnt bought the turbo yet (real soon) but yeah theyre pretty pricey.. Around 1.5k for a 2nd hand hks one. You get what you pay for though..
Sprinta
Re: 4A-GZE pistons, where to get them Sun, 14 September 2003 15:49 Go to previous messageGo to next message
You could always just get a 2mm HKS metal head gasket which drops the compression to ~8.1:1 or 1.6mm Hks gasket takes it to ~8.5 which is what ill probably do... although its up to you Smile
TecEVO
Switzerland
Re: 4A-GZE pistons, where to get them Tue, 16 September 2003 02:12 Go to previous messageGo to next message
I'm not sure but i don't think any old toyota dealer will sell stuff for the 4AGZE as it was never available here, i.e. they are all jap imports.
I think you will find that Castle Hill Toyota is a rare exception. They seem not to have any problem with imports and do a great job supporting them, hence they get our buisness why don't the other dealers catch on. They also carry real TRD stuff.
Re: 4A-GZE pistons, where to get them Tue, 16 September 2003 02:13 Go to previous messageGo to next message
Pretty much any Toyota dealer will get and be able to get import parts for you. They just won't be very helpful in most cases.
AngryMatt
Re: 4A-GZE pistons, where to get them Wed, 06 October 2004 03:34 Go to previous messageGo to next message
*holy thread resurrection ,batman*
nice price on the forged ceramic coated pistons BigWorm. wondering also .. do they sell them individually? if so ..how much .... do u have a phone number for castle hill toyota? or an address even? looking to buy 6 for a project i'm working on.
Matt
Re: 4A-GZE pistons, where to get them Wed, 06 October 2004 07:31 Go to previous messageGo to next message
yes they sell individually
get them from ANY toyota (we just use Castle Hill cos they're local, and the gay guy there knows all this type of shit)
drift86levin
brisvegas
Re: 4A-GZE pistons, where to get them Thu, 30 December 2004 06:46 Go to previous messageGo to next message
sorry for the 2nd incarnation of this old post, buy the castle hill number is in whitepages.com.au, and the guy to speak to is James.. there about $96 or $92 each incl GST (sorry i should have paid more attention..) for 13103-16131..all the guys in brisbane want $102.55 incl GST each, seems less hassle to me to just get them up here in brissy..the extra $$ is simply shipping from NSW where they would be getting them from..
ohh and alot of them asked me how i knew the part number, and i mentioned something about the EPC, they were shocked and disgraced about this info 'leaking' out to the public..weird hey...
feral4mr2
Bundaberg, Qld.
Re: 4A-GZE pistons, where to get them Thu, 30 December 2004 12:29 Go to previous messageGo to next message
depending on how high a HP gte you want the 9.4:1 casties and a thicker head gasket work fine.
Re: 4A-GZE pistons, where to get them Thu, 30 December 2004 21:07 Go to previous messageGo to next message
but if you are rebuilding, why wouldnt you spend the meagre $400 if you were replacing pistons?
At the moment i'm a broke tightarse and cant afford a set, so my 4agte is going to have the stock 10.5:1 pistons... Shocked
2000CorollaGT
Jamaica
Re: 4A-GZE pistons, where to get them Thu, 30 December 2004 21:34 Go to previous messageGo to next message
What EMS should i use for a 4AGTE setup.
So far ive aquired:
Supra TT fuel pump
4 Supra Injectors
planning on dropping in gze pistons and rods into my 4AGE20valve(Blacktop)
feral4mr2
Bundaberg, Qld.
Re: 4A-GZE pistons, where to get them Thu, 30 December 2004 21:42 Go to previous messageGo to next message
i was a broke tightarse when i was rebuilding my 4agte, so the 9.4:1 casties got used. Wink
thats what i like to hear, high comp and boost. more torque, better fuel economy and if tuned right i have read a fair whack of HP can be acheived.
i wonder if stewart (old carolla's dude) is able to determin piston strength? he did a good job with the gze pistons with their build.
after talking with one of the mechanics that deal through work, he rekons what i did useing higher c/r cast pistons and then lowering the c/r they are a stronger than forged pistons? being more brittle or something than forged pistons?
2000CorollaGT
Jamaica
Re: 4A-GZE pistons, where to get them Thu, 30 December 2004 21:48 Go to previous messageGo to next message
No Message Body
Re: 4A-GZE pistons, where to get them Thu, 30 December 2004 23:24 Go to previous message
yeah i remember having a long in-depth discussion with stew about different piston strengths and why forged pistons are used.
This is a rough *from memory*....
... a cast piston is generally better in most properties, but they are brittle and inflexible or something, meaning that they can't handle detonation conditions etc and survive - whereas a forged piston can.
Forged pistons have worse qualities as far as expansion and heat effects are concerned, but they will survive detonation and other undesirable (un-intended) conditions when a cast piston would not.
Of course i could be waaaay off the mark. Here is a thread with a good discussion of the whole thing. Be warned, there is a lot of other bullshit going on there too Razz
http://forums.toymods.org.au/index.php?t=msg&g oto=340671&rid=883&S=25643b4dcd9dd1ea120fc 235b5c318e7
Previous Topic:ST165 (3SGTE) rattling?
Next Topic:Regassing Tailgate Struts
Current Time: Fri Nov 20 18:00:19 UTC 2026
Total time taken to generate the page: 0.020030975341797 seconds
