Toymods » General Car Talk » where can i get dash converters?
V8_MA61
where can i get dash converters? Fri, 12 September 2003 12:48 Go to next message
Ok i want to try and keep my ma61 supra dash as standard as possible.
I know i have to add an oil pressure gauge somewhere.
However. I want to use the toyota tacho and temp gauge. Does someone make a converter for a v8 to i6 tacho reading? Anyone know how i can make my temp gauge work with a signal from the ford thermostat? And does someone know how i can get a rev limiter to work on my car?
Blake.
[Updated on: Fri, 12 September 2003 12:49]
Re: where can i get dash converters? Fri, 12 September 2003 15:32 Go to previous messageGo to next message
Just use a Toyota temperature sensor; drill and tap a hole with the appropriate thread in the thermostat housing of your engine. Easy.
As for the tacho thing, I'm sure there must be some way to do it - there are a few people here who have put sixes into Celica's, and I'm sure they aren't all driving around without a tacho!
Chris Davey
sunny coast, qld
Re: where can i get dash converters? Fri, 12 September 2003 23:50 Go to previous messageGo to next message
i thought they usually just put in monster tachos? That is what most of the people i know have got now.
Not me though, 1jz wires up to stock Chaser tacho in the Corona! Smile
V8_MA61
Re: where can i get dash converters? Sat, 13 September 2003 03:27 Go to previous messageGo to next message
I hate those big tachos and temp gauges with a passion! Norbie where (what toyota) can i get one of these temperature sending units from?
Would any work in conjunction with the ma61 electronic Dash, or Does it have to be an older car..???
plus to make it more difficult im running the thermo fans by a thermo controller!
[Updated on: Sun, 14 September 2003 01:42]
V8_MA61
Re: where can i get dash converters? Sun, 14 September 2003 03:33 Go to previous messageGo to next message
Did someone on toymods sell a tacho converter or something?
Re: where can i get dash converters? Sun, 14 September 2003 03:53 Go to previous messageGo to next message
Any Toyota temp sensor will do the job; they all do the same thing, so Toyota never bothered changing them!
V8_MA61
Re: where can i get dash converters? Sun, 14 September 2003 04:40 Go to previous messageGo to next message
sweet..im guessing i should buy a NEW one, or would a used one be ok? Do i just need the sensor? Would it have the same wire plug/fitting as the 5m one?
because come to think of it i remember in the loom off the 5me i have hanging out of my bonnet i have one market "temp sensor"..
wilbo666
Re: where can i get dash converters? Sun, 14 September 2003 07:38 Go to previous messageGo to next message
I'll bring ya a spare temp sensor around when I come by tonight Smile
BlackSupra
Re: where can i get dash converters? Sun, 14 September 2003 08:20 Go to previous messageGo to next message
'Grant' sells tacho adapters
yours may be a special order item
sideshow
Re: where can i get dash converters? Sun, 14 September 2003 10:37 Go to previous messageGo to next message
grant form sixworks sells tacho boosters that amplify the signal
not sure if he does adapters from 8cly to 6
there is a guy that can modify yr original tacho to suit an 8cyl
he modifys the circuitry in the back of the tacho
not to sure if u can actually get adapters frpm 8cyl to 6cyl
his busniess name is MIS
mobile instrument services
or u could try general auto instruments in lidcome sydney
suprav8
melbourne
Re: where can i get dash converters? Sun, 14 September 2003 10:41 Go to previous messageGo to next message
You can use your 5me temp sensor,all you need is to buy a adapter to screw into your V8(which is available).....I don`t trust factory guages and considering windsor`s love to overheat maybe you should go for a small aftermarket guage.......i have a temp and oil guage just above my cd player and it doesn`t look "out of place".....just a suggestion.
As for the tacho i can see no reason why the factory one can`t be used but it will take a electronic guru to sort it out(be well worth it though).........i`m still trying to get mine to work Smile
V8_MA61
Re: where can i get dash converters? Sun, 14 September 2003 11:03 Go to previous messageGo to next message
im not gonna argue, but windsors are no worse than other v8s for overheating. Yeah i dont care about changing the tacho $ wise...will end up cheaper than a decent vdo one anyway. toyota tachos - They dont have any warnings or anything do they when you get into the old toyota red line?
[Updated on: Sun, 14 September 2003 11:08]
sideshow
Re: where can i get dash converters? Sun, 14 September 2003 11:32 Go to previous messageGo to next message
from past experience i think the thread on yr 5m temp sensor is the large thread type
and from looking at the temp sensor on the 1uz it has a small thread
im not 100% sure but its just from hwat i remember seeing
1uz has similar type of sensor as a 4ag20v think its 1/4bsp
and i think the 5m is but double the size
not to sure if u can drill and tap the 1uz
the temp sender is in a prick of a spot under the top front cover near the coil
ed_ma61
Lost in the K hole
Re: where can i get dash converters? Sun, 14 September 2003 11:47 Go to previous messageGo to next message
sideshow wrote on Sun, 14 September 2003 21:32
its a big assumption that we're talking about a 1uz here lol! Rolling Eyes
cheers!
ed
sideshow
Re: where can i get dash converters? Sun, 14 September 2003 11:52 Go to previous messageGo to next message
yer the temp sender is hidden under the covers where as the oil senderis under the left hand rear section of the engine
V8_MA61
Re: where can i get dash converters? Sun, 14 September 2003 12:37 Go to previous messageGo to next message
ill have to use a milling machine to make a thread for the toyota sensor...wilbo gave me a sensor unit from a 5m, should work shouldnt it?
can someone tell me exactly who can fix my tacho situation?
sideshow
Re: where can i get dash converters? Sun, 14 September 2003 12:44 Go to previous messageGo to next message
ring a place called
general instrument services
theyre in lidcome
and tell them yr situation
see what they say
do u have the digital dash
do u have warnign light or gauge
y not just use oil sender that came with 5m
if its a light just use oil pressure switch
V8_MA61
Re: where can i get dash converters? Sun, 14 September 2003 14:54 Go to previous messageGo to next message
yeah i have the digital dash..so a bit harder than the needle one? I mean it has lights for when the pressure is low...
[Updated on: Sun, 14 September 2003 15:01]
V8_MA61
Re: where can i get dash converters? Sun, 14 September 2003 15:00 Go to previous messageGo to next message
come to think of it, no im not gonna risk using a toyota sensor alone, am going to use a ford one with a gauge in my dash somewhere. Ive spent too much money to risk using a wrong type of sensor
wilbo666
Re: where can i get dash converters? Mon, 15 September 2003 00:23 Go to previous messageGo to next message
I can't see a problem with using the Toyota water sensor (all it does is measure the water temp, it doesn't give a hoot about what motor it is!), but I guess if your paranoid it would be a good move to setup another temp gauge until you are sure that the dash one is working correctly. Smile
V8_MA61
Re: where can i get dash converters? Mon, 15 September 2003 11:12 Go to previous messageGo to next message
temp sensors fine wilbo, was referring to the oil pressure sensor Smile Will find out more about the tacho and let you all know!
Allan
Re: where can i get dash converters? Tue, 28 October 2003 01:58 Go to previous message
V8_MA61 wrote on Sun, 14 September 2003 21:03
optimistic redline for a iron v8 even the ol' 5m-e does 6200rpm Very Happy
Allan
....was just looking for digital dash stuff Razz
Previous Topic:Where to get....?
Next Topic:7M Lovers Ready to Blow some loadage!
Current Time: Mon Oct 19 08:42:04 UTC 2026
Total time taken to generate the page: 0.1622040271759 seconds
