Toymods » Tech & Conversions » 2zz-ge specs??
quick
2zz-ge specs?? Sat, 13 September 2003 18:15 Go to next message
any specs on the new 2zz from the late model silly car....rich friend of my dads just got one couple days back and its 6-spd man and is brand new-ish and 100% stock
-2zz performance figures would be something impressive i could throw at him next time i go see him
-plus ive heard from a ta22 owner that the new sillycars are shit
-fill me in boys n girls /hairdressers....(sorry celica joke...couldnt help myself)
manipulate
Re: 2zz-ge specs?? Sun, 14 September 2003 01:15 Go to previous messageGo to next message
from a quick google search i got a general consensus of:
180hp @ 7600 RPM (USA models only japan, australia, new zealand models may vary)
130 lb/ft @ 6800 RPM
180hp converts to 134 kw
130 lb/ft ..... dunno what that converts to in nm
anyone know how to convert to nm ?
Ta
Mani
[Updated on: Sun, 14 September 2003 01:18]
shinybluesteel
melbourne
Re: 2zz-ge specs?? Sun, 14 September 2003 03:35 Go to previous messageGo to next message
176.2566 N.m
look up convert.exe in google, and you will find a program hat will convert nearly ny unit into nearly any unit
ZZT231
melbourne.vic.au
Re: 2zz-ge specs?? Sun, 14 September 2003 07:21 Go to previous messageGo to next message
To find more details on the ZZT231, go to New Celica Webpage (USA)
The engine between the 2003 and the 2000 hasn't changed much though the red line in the 2000 is at 7800rpm and the 2003 is at 8400rpm *Exact figures I can't remember*.
This is what was taken off the Toyota.com.au Website on the engine.
Quote:
Maximum Power 140kW @ 7600rpm
Maximum Torque 180Nm @ 6800rpm
Hope that helps
Cheers.
[Updated on: Sun, 14 September 2003 07:22]
Jards88
Re: 2zz-ge specs?? Mon, 15 September 2003 23:50 Go to previous message
From the 2000 Celica Owners Manual.
Engine Type: 2ZZ-GE 4 Cylinder, in-line
Displacement: 1796cc
Valve mechanism: Variable Valve Timing and Lift Intelligent (VVT-Li)
Valve Train: Twin Cam
Bore & Stroke (mm): 82.0 x 85.0
Compression ratio: 11.5:1
Max Power: 140 kW @ 7600RPM (188bhp)
Max Torqe: 180 Nm @ 6800RPM (133 ft/lbs)
Fuel System: Electronic sequential multi-point Fuel Injection
Fuel required: 95 RON (Premium Unleaded)
Ignition System: Distributorless, Electronic Direct Ignition System
The earlier models were redlined at 7800RPM and fuel cutoff is at 8300RPM or thereabouts. I believe the Corolla Sportivo is redlined at 8300, I don't know if the current Celica is redlined any higher or not, certainly the UK & Japanese models were. In any case maximum performance can only be realised by changing as close to fuel cut as possible to try and keep the engine on the high lift cam.
Previous Topic:Driving Lights
Next Topic:Where to get a 4.1 G series center?
Current Time: Mon Oct 19 01:08:03 UTC 2026
Total time taken to generate the page: 0.005422830581665 seconds
