Toymods » Tech & Conversions » 4age flywheel problem
shindeokure
melbourne
4age flywheel problem Sun, 14 September 2003 03:50 Go to next message
i'm putting a rwd 4age into an ae86 and am having trouble finding the right clutch for it.
the flywheel is 188mm.. anyone know of the daiken hd clutch kit code for this? the guy at a store had listings for 200mm and 215mm, but can't match up one for mine.
[Updated on: Sun, 14 September 2003 12:36]
TE72_Turbo
Re: clutch kit selection Sun, 14 September 2003 04:09 Go to previous messageGo to next message
185mm? where did your flywheel come from ?? Are you using a T50 gearbox? I'd seriously consider ditching the flywheel you have and fitting a "normal" 200mm 4AGE flywheel.
shindeokure
melbourne
Re: clutch kit selection Sun, 14 September 2003 09:16 Go to previous messageGo to next message
it supposedly came off the rwd 4age that came with the engine. does anyone know if the rwds have different flywheels?
TE72_Turbo
Re: clutch kit selection Sun, 14 September 2003 11:05 Go to previous messageGo to next message
As far as i know, the RWD 4AG's only came out with 200mm flywheels.
shindeokure
melbourne
Re: clutch kit selection Sun, 14 September 2003 12:10 Go to previous messageGo to next message
http://forums.melbccr.com/uploads/357167-flywheel.jpg
28mm width
7kg.
any idea if this is actually a 4age flywheel?
and which clutch i should use for it?
[Updated on: Sun, 14 September 2003 12:53]
shindeokure
melbourne
Re: clutch kit selection Sun, 14 September 2003 13:11 Go to previous messageGo to next message
Quote:
Flywheels & clutches
The flywheels on all the 4AGE's are held on with eight extremely high quality bolts. They are fine for all amounts of power. The AE-86 flywheel is a little smaller than the others, and so is the clutch assembly. In fact the clutch on the AE-86's 4AGE is exactly the same as the single cam 4AC. Not entirely sure if that's a good thing, but it seems to last okay and makes it pretty cheap & easy to get new ones. FWIW, I think that the 3TGTE clutch assembly should bolt straight on, and if so, it would be a good thing as they can take 160ft-lbs of torque - A lot more than the 4AGE clutch is designed for.
The other 4AGE's have a flywheel & clutch that is about 12mm larger in diameter, and so they are not interchangeable with the AE-86 unit.
( http://www.billzilla.org/4agstock3.htm )
ok.. so it is a rwd 4age flywheel.
now, should i use it? or buy a 200mm flywheel?
does anyone know if it would make any difference, performance wise?
can anyone confirm that the 3tgte clutch kit will fit?
part number?
does anyone in melbourne have a 200mm one lying around that they wouldn't mind giving me?
[Updated on: Sun, 14 September 2003 13:14]
TE72_Turbo
Re: clutch kit selection Sun, 14 September 2003 13:28 Go to previous messageGo to next message
which part of that quote from bill's site makes you think that the flywheel you have is a RWD 4AGE one? I still think that the "12mm bigger one" that bill is referring to is actually the one that people commonly say is 215mm, as fitted to the 100kw (FWD only) red top 4AGE's. All bluetop 4AGE's (RWD or FWD) and the AE86's 4AC use a 200mm face flywheel. I'm still unsure where you're 188mm one could have come from... Smile
BTW: in that picture you took, is there no locating dowels for the clutch pressure plate, or is my eyesight really bad?
shindeokure
melbourne
Re: clutch kit selection Sun, 14 September 2003 13:42 Go to previous messageGo to next message
i dunno.. supposedly from a rwd 4age. i'm sure alot of you guys out there would have used rwd 4ages in ae86 conversions? does it look familiar?
as for the dowels, i'd have no idea. i'm not fitting it, so i don't really know too much about it.. but the guy who machined it said it's not gonna fit any of the 4age clutches listed.
if i am correct, my 4ac clutch should fit nicely, right? i will inspect it tomorrow.
btw, it has "16020" embossed on the back, if that helps.
[Updated on: Sun, 14 September 2003 13:44]
TE72_Turbo
Re: 4age flywheel problem Sun, 14 September 2003 13:51 Go to previous messageGo to next message
I saw my flywheel being removed from an import RWD AE86 4AGE, so its definately the real deal, and has a 200mm face, same as the front wheel drive blue top 4AGE (AE82) and the AE86 RWD 4AC Smile
shindeokure
melbourne
Re: 4age flywheel problem Mon, 15 September 2003 07:12 Go to previous message
i checked the 4ac flywheel.. you're right, it's bigger. i'll have to find a new one.
i also called toyota today.. apparently fwd & rwd flywheel bolts have a different part number?
[Updated on: Mon, 15 September 2003 07:41]
Previous Topic:AE82 twin cam DONE conversions (in this club)
Next Topic:Cost of Rebuild to 4age 16 valve 100kw
Current Time: Fri Oct 16 10:04:40 UTC 2026
Total time taken to generate the page: 0.059786796569824 seconds
