Toymods » Tech & Conversions » ARP Head stud torque settings.
celicaboy_2000
Lismore, NSW
ARP Head stud torque settings. Sun, 14 September 2003 08:55 Go to next message
Hey, Just want to know what I should torque me ARP headstuds up to in my 7MGTE. And also what should I torque the nuts to when I put the head on? Im using a 1.5mm CHG if that changes anything...
Re: ARP Head stud torque settings. Sun, 14 September 2003 09:15 Go to previous messageGo to next message
70lb/ft from memory of the thousands of times this has been discussed
do a search Smile
kmwdesign777
adelaide
Re: ARP Head stud torque settings. Sun, 14 September 2003 09:31 Go to previous messageGo to next message
Hi, when you put in the head studs they are only put in finger tight... about 4 ft/lbs. The torque on the nuts..70 sounds about right.
ARP have a great web site at www.arp-bolts.com
regards kevin.
celicaboy_2000
Lismore, NSW
Re: ARP Head stud torque settings. Sun, 14 September 2003 10:04 Go to previous messageGo to next message
Cheers for that.
Stenno
Re: ARP Head stud torque settings. Sun, 14 September 2003 11:33 Go to previous messageGo to next message
It's 70ft/lbs providing you're using the ARP moly lube.
If you're using normal engine oil on the threads, it's 85ft/lbs.
TD42T
Mildura
Re: ARP Head stud torque settings. Sun, 14 September 2003 12:32 Go to previous messageGo to next message
Studs are finger tight.
80ft/lbs with ARP lube(or any assemblylube)
100ft/lbs with engine oil(can't remember the weigth oil they recommend)
Marty
ed_ma61
Lost in the K hole
Re: ARP Head stud torque settings. Sun, 14 September 2003 14:24 Go to previous messageGo to next message
95ft/lbs with the arp lube
125ft/lbs with pamolive liquid hand wash
seriously, its 70ftlbs with the arp lube
and ~85ft/bs with 30wt engine oil
Allan
Re: ARP Head stud torque settings. Mon, 15 September 2003 08:01 Go to previous messageGo to next message
I did 120ft/lbs with engine oil, i run 11psi every day and its now 4 months no issues use washers off an old magna head thay are the right size and flat both sides (pick-a-part is the place to get them)
Allan
celicaboy_2000
Lismore, NSW
Re: ARP Head stud torque settings. Mon, 15 September 2003 10:03 Go to previous messageGo to next message
Ok so if I was to use KY jelly what tension should it be then??? Thanks people's
TD42T
Mildura
Re: ARP Head stud torque settings. Mon, 15 September 2003 11:28 Go to previous messageGo to next message
Yes sorry I was wrong, memory not that great.
Here is the chart.
A 12mm 220,000psi stud is ?
http://www.arp-bolts.com/pages/tech/images/fasttor q.pdf
Marty
manipulate
Re: ARP Head stud torque settings. Mon, 15 September 2003 11:32 Go to previous message
this thread is has turned out to be damn handy
thanx heaps guys
Previous Topic:AE86 clutch
Next Topic:4AGE Rev Limit?
Current Time: Sun Oct 11 19:08:00 UTC 2026
Total time taken to generate the page: 0.017019987106323 seconds
