Toymods » Tech & Conversions » 4agze - what oil works best?
krayzie
4agze - what oil works best? Sun, 14 September 2003 09:11 Go to next message
Im not sure what oil to put into my 4agze. Im currently running a 5W-40 in my WRX and was going to put the same in the 4agze. Is this to thin?
What are you guys running in your 4agze?
Re: 4agze - what oil works best? Sun, 14 September 2003 09:14 Go to previous messageGo to next message
dpends what condition it's in
generally I'd say that's too thin for an oldish 4a-gze, but if it's in great nick/rebuilt... then it could work fine.
I'd suggest a good 10-50, assuming your engine doesn't blow any smoke.
if it does, might have to go a bit thicker
FKN16V
NSW, East Coast
Re: 4agze - what oil works best? Sun, 14 September 2003 09:36 Go to previous messageGo to next message
I had a small oil leak around my sump, i was using 10w-40w then i change to magnatec, the one with the molicuals that stick to metal to avoid start-up damage, and the difference is awesome, the idle is alot smoother and take off is improved 1000%, stop the leak too.
I fully recommend it.
But generally what Draven says is pretty much the same as i wouldve said.
Hope it works out.
FWIW try a compression check, you never know what condition your rings are in.
TE72_Turbo
Re: 4agze - what oil works best? Sun, 14 September 2003 11:47 Go to previous messageGo to next message
This has been covered quite a few times before.
I personally run Shell Helix Ultra (5W-40 from memory) and find that it helps with cold starting, and quitens down a lot of noise in the head when cold. For some reason my GZE makes a fairly audible knocking noise in the head when running anything higher than a 10W oil until it gets hot (& no, its not the usual forged piston slap Smile )
Penrite HPR15 seems to be another popular option.
Phil
krayzie
Re: 4agze - what oil works best? Sun, 14 September 2003 20:29 Go to previous messageGo to next message
I think I will stay with the 5W-40 and see how we go with that.
While Im on the topic of oils ..... What weight oil for a T50 box would be best. Any brands stand out over the rest? What are you guys using?
Andrew
Corvid
Re: 4agze - what oil works best? Sun, 14 September 2003 21:43 Go to previous message
I run Penrite HPR30 and swear by it.. as does alot of the population.
Previous Topic:what t-series came with what ratio?
Next Topic:4AGZE Wieght Difference
Current Time: Thu Oct 29 09:43:07 UTC 2026
Total time taken to generate the page: 0.069638013839722 seconds
