Toymods » Tech & Conversions » water temp sensor / dash display for a 2j conversion
BlackSupra
water temp sensor / dash display for a 2j conversion Sun, 14 September 2003 10:29 Go to next message
The water temp sensor on a 2j between 60~120 degress is represented by a voltage of 0.2 ~1.0 Volts.
What is the default on an MA61?
Can i just wire the standard sensor output straight up to the dash and have correct operation or is it a little more difficult than that?
ta guys.
[Updated on: Sun, 14 September 2003 10:29]
sideshow
Re: water temp sensor / dash display for a 2j conversion Sun, 14 September 2003 10:32 Go to previous messageGo to next message
just pull the original sensor from the original engine and fit it to the new engine
then yr dash will read correctly
sometimes the thread size is different so might not be an easy job
Re: water temp sensor / dash display for a 2j conversion Sun, 14 September 2003 10:51 Go to previous messageGo to next message
No need to swap the sensor. I'm using a 2JZ sensor with my MA61 temp gauge and it works fine.
BlackSupra
Re: water temp sensor / dash display for a 2j conversion Sun, 14 September 2003 11:07 Go to previous message
sah weeeeet Cool
ta norbie.
Previous Topic:Extractors
Next Topic:Which Brake Booster? 165 or 162
Current Time: Thu Oct 29 23:54:26 UTC 2026
Total time taken to generate the page: 0.10393500328064 seconds
