Toymods » Tech & Conversions » [Tech] Walbro install into Supra info here.
wastegate
Gold Coast
[Tech] Walbro install into Supra info here. Sun, 14 September 2003 11:58 Go to next message
Well thanks to 7M-Brisbane and Norbie for giving a hand, I installed a Walbro pump yesterday, thought I would document it incase any other Supra owner wants to do the same.
http://www.jzgte.com/~nickc/albums/Walbro/DSC00006.thumb.jpg
First unscrew the 4 screws holding the cover of the fuel filler on and take it out.
http://www.jzgte.com/~nickc/albums/Walbro/DSC00008.thumb.jpg
Jack the car up under the diff and put jack stands under the car as you will need the jack to help support the fuel tank.
http://www.jzgte.com/~nickc/albums/Walbro/DSC00009.thumb.jpg
Unbolt the plastic shroud cover at the front of the fuel tank. There are 4 bolts to undo. It's can be alittle tricky to get out.
http://www.jzgte.com/~nickc/albums/Walbro/DSC00011.thumb.jpg
Here is the cover undone.
http://www.jzgte.com/~nickc/albums/Walbro/DSC00012.thumb.jpg
You will need to undo these lines to get the tank out. One of the clamp hoses is the breather and the other the fuel return line. The bolted section is the high pressure line. You will need a 19mm and a 14mm to undo this. The 19mm section is the one that undoes. Watch for fuel spillage here as there will be abit if the line is still under pressure.
http://www.jzgte.com/~nickc/albums/Walbro/DSC00013.thumb.jpg
Here are the two bolts that hold the fuel tank up. Undo these bolts but not off. Only loosen them off abit.
http://www.jzgte.com/~nickc/albums/Walbro/DSC00016.thumb.jpg
Unplug the fuel level sender sensor wires from within the boot.
http://www.jzgte.com/~nickc/albums/Walbro/DSC00017.thumb.jpg
Now with the jack and a peice of wood/books to spred the weight onto the jack, put it under the tank between the two straps. Now jack it up alittle to give the belts some slack. Take out the pins for the belts and undo the bolts to remove the belts.
http://www.jzgte.com/~nickc/albums/Walbro/DSC00018.thumb.jpg
Reach up and disconnect the fuel pump connector from the car.
http://www.jzgte.com/~nickc/albums/Walbro/DSC00020.thumb.jpg
With abit of loweringof the jack the tank should be able to be lowered out, make sure that the tank comes to the passinger/left side of the car while it's lowering to get the filler out.
wastegate
Gold Coast
Re: [Tech] Walbro install into Supra info here. Sun, 14 September 2003 11:58 Go to previous messageGo to next message
http://www.jzgte.com/~nickc/albums/Walbro/DSC00022.thumb.jpg
Remove the screws that hold the fuel pump backet in and remove with a slight twist. Make sure you know how it came out as you have to put it in the same way.
http://www.jzgte.com/~nickc/albums/Walbro/DSC00023.thumb.jpg
Fuel Tank with Stock Pump
http://www.jzgte.com/~nickc/albums/Walbro/DSC00027.thumb.jpg
Here is the Walbro installed on the bracket. I had to cut the bottom of the braket to open up the hole alittle so the walbro fits though. Take note of the wires because if you put the wires on the wrong way the pump goes backwards and the car doesn't run.
http://www.jzgte.com/~nickc/albums/Walbro/DSC00028.thumb.jpg
Here is the Walbro on the braket. With the wiring I just used spade terminals crimped onto the wiring. You will need to install the filter onto the bottom of the pump of course. Make sure the filter faces the same way as the old one otherwise you can't reinstall the pump.
Guest
Re: [Tech] Walbro install into Supra info here. Sun, 14 September 2003 12:19 Go to previous messageGo to next message
How much did the walbro cost you ??
Matt
wastegate
Gold Coast
Re: [Tech] Walbro install into Supra info here. Sun, 14 September 2003 12:25 Go to previous messageGo to next message
umm $250 I think it was from Petroject.
Guest
Re: [Tech] Walbro install into Supra info here. Sun, 14 September 2003 12:29 Go to previous messageGo to next message
Ta, I already have one. I was just wondering if i got a good deal. Great pumps apparently.
Matt
crazy_camry
Re: [Tech] Walbro install into Supra info here. Sun, 14 September 2003 12:30 Go to previous messageGo to next message
could they flow 255lph and provide 110psi of fuel pressure? (thses are the numbers i've got from some one who has turboed the same kind of car as me).
Guest
Re: [Tech] Walbro install into Supra info here. Sun, 14 September 2003 12:33 Go to previous messageGo to next message
If it is the same as mine then yes easy.
Matt
crazy_camry
Re: [Tech] Walbro install into Supra info here. Sun, 14 September 2003 12:36 Go to previous messageGo to next message
cool. i'll have to get in contact with Petroject then.
Re: [Tech] Walbro install into Supra info here. Sun, 14 September 2003 12:43 Go to previous messageGo to next message
Excellent work Nick, I'm sure someone will find that extremely useful. FWIW the procedure is almost identical for an MA61; I did mine about 6 months ago.
As for flow rates, yes the high-pressure Walbro pump can flow 255 lph and yes it can provide 110 psi fuel pressure, but it can't do both at the same time! They flow approx 320 lph at 0 psi and 35 lph at 110psi. Flow data can be found here.
The above web site retails Walbro high-pressure pumps for USD$109, and they're available with plug-n-play kits for MA61 and MA70 Supras. That's where I got mine from and it was a piece of piss to install as it had the correct wiring, fuel hose, rubber mount etc all ready to go. Smile
crazy_camry
Re: [Tech] Walbro install into Supra info here. Sun, 14 September 2003 12:53 Go to previous message
Norbie wrote on Sun, 14 September 2003 22:43
yeah sorry it was 110psi fuel pressure at 7psi
Previous Topic:Head swap necessary......
Next Topic:Extractors
Current Time: Fri Oct 30 13:24:10 UTC 2026
Total time taken to generate the page: 0.060499906539917 seconds
