Toymods » Tech & Conversions » I'm a newbie - need directions...
Noodlebut
I'm a newbie - need directions... Sun, 14 September 2003 12:54 Go to next message
Hey, i just bought a '89 AE92 SX Hatch. i opened the bonnet and took a look at the radiator and the coolant bottle and noticed that they are filled with a brown liquid - my guess is rusty water?...
i just needed some directions on how to flush it all out?.. ive been told its an easy job - so i dont wanna be wasting money by taking it to the mechanics when its something i could probably do.
any help would be appreciated.
cheers.
Re: I'm a newbie - need directions... Sun, 14 September 2003 13:08 Go to previous messageGo to next message
as a real easy start, look to see if there as a drain plug on the bottom of the radiator (like a stopcock).
if so, then open it and let all the shit drain out. (preferably onto grass??). if not, then pull off the bottom radiator hose connects to the radiator, and drain it out that way.
then refill with water, take the car for a drive, then drain.
keep doing that until the water comes out clear...
you can use 'radiator cleaner' but the stuff is usually caustic, and will eat away metal from somewhere (i guess)...
you can also pull the radiator out of the car, and fluch it using a hose.. again keep fluchin till the water comes out clear, and run the water in both directions...
once the water stays clean in the car for a drive or two, then drain out, fill with XX amount of ehtylene glycol (coolant concentrate) then top up with water....
i like abour 30% coolant to water, but some ppl like more or less..
STR8 2.8
Re: I'm a newbie - need directions... Sun, 14 September 2003 13:32 Go to previous messageGo to next message
all i did when i flushed it was drain it and stick i hose in the filler neck and flush it out nice and good, then pour in some new stuff.
easy peasy
redlineGTi
syd- green valley
Re: I'm a newbie - need directions... Mon, 15 September 2003 05:21 Go to previous messageGo to next message
dude make sure that it is rusty water first because genuine toyota coolant is a rusty/brown color, unlike aftermarket stuff which is green.
ed_ma61
Lost in the K hole
Re: I'm a newbie - need directions... Mon, 15 September 2003 05:44 Go to previous messageGo to next message
oldcorollas wrote on Sun, 14 September 2003 23:08
stewart - id be rather wary of simply undoing the drain plug on old rusty cooling systems - the number of times ive seen the things never make a full seal again when you tighten them... if its not leaking, my moto is to not open it Smile
i prefer to just drop the bottom hose off - much faster too Very Happy
and regarding the refilling process - note that it may take SEVERAL attempts at filling the system before you can be assured that there is no air left. take it for a drive, turn the heater on, park it on a slope etc etc ... and just keep adding water over the next few days
ed
manipulate
Re: I'm a newbie - need directions... Mon, 15 September 2003 09:03 Go to previous messageGo to next message
yeah what ed said make sure u get rid of all the air in the cooling system and use the bottom hose to drain the system
in regards to the brown muck
is it milky gooey brown ?
or is it just normal water but just brown
if the brown shit is kinda thickish and milky then you could have a blown head gasket
and when u flush it all out do it properly
dont just do the radiator do the whole system
take the thermostat out and do a flush in both directions of the heater hoses....making sure your heater is "ON" inside the car
this isnt neccesary for a normal coolant change but it is in this case cause your whole system is dirty
Ta
Mani
[Updated on: Mon, 15 September 2003 09:04]
Noodlebut
Re: I'm a newbie - need directions... Mon, 15 September 2003 12:27 Go to previous messageGo to next message
thanks people, doing the radiator sounds pretty straight forward and simple.
manipulate, any cahnce you could give me any more info on "the whole system"... remember im a newbie so i basically know nothing...
any chance someone could give me directions on doing the whole thing?
and i got an nrma inspection on the car before i bought it... they said rusty water so yeah... it should be just that...
the guy a bought it off said it was rusty water too...
manipulate
Re: I'm a newbie - need directions... Mon, 15 September 2003 12:30 Go to previous message
OK if the NRMA dudes didnt say it was a blown HG then it should be cool....cause its an obvious difference
well by doing the whole system i mean...exactly that
not just the radiator but go through the whole thing...
get a hose....stick in all the heater hoses in all directions to get all the crap out till the water comes out clear and taking out the thermostat too like i said b4
sorry i cant xplain this well its hard to xplain with words and no pics
fuck it where do u live
come round and ill do it for u ...
2o minutes
Previous Topic:2S-C
Next Topic:Tyre size
Current Time: Wed Nov 25 22:32:41 UTC 2026
Total time taken to generate the page: 0.0084929466247559 seconds
