Toymods » Tech & Conversions » Installing Guages
isaac
Helensvale, Queensland
Installing Guages Sun, 14 September 2003 22:49 Go to next message
Hey, i am thinking of installing 3 guages in the little area below the CD player (where cup holders are) of my 1990 Celica. The guages I want so far are a tacho and vacuum pressure. They are all going to be small guages like 5cm's or something. I know how to install head units and the basics of car electronics EG relays diodes, lights and stuff, but how hard would it be to wire up the gauges. Getting the plastic and installing the guages into the dash will be easy, but how are these types of things wired up?
Thanks alot
Re: Installing Guages Mon, 15 September 2003 00:19 Go to previous messageGo to next message
very easily.
the boost gauge (vac pressure) will have 1 hose you connect to your inlet plenum, and 2 wires which you connect to a power source to light the gauge. make sure it's a variable source (like your dash lights or ciggy lighter) if you want to be able to dim them.
tacho likewise *should* be easy, but check first with someone who knows what the output is of the 1990 celica tacho wire... most a/m tachos use 12v
Re: Installing Guages Mon, 15 September 2003 00:54 Go to previous messageGo to next message
Whats the point of having a tacho down there? Doesn't a Celica already come with one? There is no real point to having it so far out of line of sight because it loses its usefulness.
This is why most new "performance" cars have a large tacho front and centre in the dash.
isaac
Re: Installing Guages Mon, 15 September 2003 02:57 Go to previous messageGo to next message
Yeah I do have a taco in the dash, and it's nice and big, the same size as the speedo. I just wanted one there because i was going to put the vacuum guage in there anyway, and i thought it would look lonely Razz
wilbo666
Re: Installing Guages Mon, 15 September 2003 03:05 Go to previous message
Why not put a gauge you don't have already? Cool ammeter, voltmeter (if you dont have one already), oil pressure (if you only have a low pressure light) or an oil temp gauge in with it?
Previous Topic:What thermo fan to use (ae86)
Next Topic:Flywheel Query
Current Time: Mon Oct 19 08:52:21 UTC 2026
Total time taken to generate the page: 0.033211946487427 seconds
