Toymods » Tech & Conversions » axle tramp
Guest
axle tramp Mon, 15 September 2003 13:19 Go to next message
Does anyone have any tips for reducing axle tramp in my jza70?
Before i changed clutch to this sprung button unit axle tramp did not exist. Now it is hard to drive in traffic without it !!!
It seems to start a little clutch shudder and then the axletramp starts.
Any ideas ?
Cani fix/adjust/replace anything to reduce it ?
The only way to get off thelien without major trouble is to instantly light the rears Surprised
not good for racing.
Matt
Re: axle tramp Mon, 15 September 2003 13:23 Go to previous messageGo to next message
tighter rear springs!
Guest
Re: axle tramp Mon, 15 September 2003 13:27 Go to previous messageGo to next message
dont know if that would help.
when adjusted to its hardest setting the shocks make it very hard already.
I went looking for worn bushes in the rear but it is all good.
I suspect this has something to do with my las blown diff as it had a big shudder and went BANG.
Matt
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: axle tramp Mon, 15 September 2003 23:17 Go to previous messageGo to next message
Shocks control the movement.
Springs prevent the movement.
It's worth a try.
What springs do you have in there?
Re: axle tramp Mon, 15 September 2003 23:52 Go to previous messageGo to next message
Maybe if you stop dropping the clutch at 7500+rpm the axle tramp will lessen Evil or Very Mad Sure it's tramp, not some kind of nasty vibration?
Guest
Re: axle tramp Tue, 16 September 2003 07:41 Go to previous messageGo to next message
It has KYB adjustable shocks in reasonable condition. Not sure of what springs are in it. It is very low. Like said it wasnt such a problem till I changed clutches.
Someone said to me the other day it was my hard worn out tyres ???
anyone else think this might be the case ?
It doesnt seem to tramp when i do flog the crap out of it, it is usually started when my clutch gives a little shudder wehn trying to slip it a little for a fast launch.
So it is launches in the 3000-4000 with a small slip that give me the most trouble.
Matt
Allan
Re: axle tramp Tue, 16 September 2003 10:52 Go to previous messageGo to next message
If its very low it maybe squating onto the bump stops/stops in the shockers?
Allan
gold28
Madrid - Spain
Re: axle tramp Wed, 17 September 2003 03:23 Go to previous messageGo to next message
I think your car has a semi trailing arm hasn't it??
If it has been lowered, you have changed your thrust line, causing more energy to be put into the springs during the launch. I bet your car squats then you launch it hard.
Are you sure it is not a problem with the clutch?
Re: axle tramp Wed, 17 September 2003 04:36 Go to previous messageGo to next message
Double wishbone IRS, not trailing arm.
Guest
Re: axle tramp Wed, 17 September 2003 06:58 Go to previous messageGo to next message
It still squats hard on a launch.
I am investigating my clutch atm, I think even for its extreme specs it shudders too much.
Matt
gold28
Madrid - Spain
Re: axle tramp Wed, 17 September 2003 21:44 Go to previous messageGo to next message
If it is squatting hard, it sounds like too much energy is being put into the suspension. With a clutch like that it pits a lot of shock type load on the whole drive train. The energy has to go somewhere and it looks like too much of it is going into pushing the bum of your car down and not enough pushing it forward.
Double wishbone setups are difficult to modify, so I would look first at tightening up all the pivot points, make sure the bushes are not deteriarated. You could even look at replacing them for something harder, however this detract from ride quality.
Short of that look at using stiffer shocks. You said you shocks were adjustable, is it just for rebound or bump as well? I guess you would want them hard on bump and softer on rebound.
Ribbo
Northern Beaches
Re: axle tramp Wed, 17 September 2003 21:50 Go to previous message
from what I have heard the more extreme your clutch ie. less pucks and higher clamping pressure = more shudder when being slipped, due to the clutch gripping then breaking then gripping again. The less pucks on the clutch and the more clamping pressure causes this more because it can't slip.
With my brass button if I get things wrong with the accel and clutch it shudders like a bitch.
Previous Topic:Need 1jz front mounted sump. What are my options?
Next Topic:Electrical meltdown
Current Time: Thu Nov 19 11:35:43 UTC 2026
Total time taken to generate the page: 0.0064890384674072 seconds
