Classifieds » Parts Wanted » MA61 gearbox to speedo cable elbow
7mgte83
Barossa valley SA
MA61 gearbox to speedo cable elbow Tue, 16 September 2003 01:33 Go to next message
I'm after the right angle piece that screws onto the end of the speedo cable and into the gearbox.
Cressida Supra
Re: MA61 gearbox to speedo cable elbow Wed, 17 September 2003 04:52 Go to previous messageGo to next message
i have one
but the cable has broken in the middle of it
i'm not sure if its repairable tho
7mgte83
Barossa valley SA
Re: MA61 gearbox to speedo cable elbow Wed, 17 September 2003 08:12 Go to previous messageGo to next message
the casing on mine is broken off where it screws into the gearbox, so I may be able to use the different parts to make one good one. hom much do you want for it? can you send it COD?
SupraBOY
Yeppoon/Rockhampton
Re: MA61 gearbox to speedo cable elbow Wed, 17 September 2003 13:57 Go to previous messageGo to next message
i don't think you need it.
take the elbow bit off and try screwing the speedo cable directly into the gearbox... i think that is how mine is connected cuz the exhaust guy totally fucked it up.
._T_.
Re: MA61 gearbox to speedo cable elbow Wed, 17 September 2003 22:03 Go to previous messageGo to next message
lots of toyota auto boxes use the angle drive fitting
T
7mgte83
Barossa valley SA
Re: MA61 gearbox to speedo cable elbow Thu, 18 September 2003 00:17 Go to previous messageGo to next message
I'll try screwing the cable directly into the gearbox.
does anyone know how standard this part is? My box is a manual is there any other more common Toyotas that would have the identical part?
SupraBOY
Yeppoon/Rockhampton
Re: MA61 gearbox to speedo cable elbow Thu, 18 September 2003 00:28 Go to previous messageGo to next message
you should be right. i'm about 99.9% sure it will screw straight in.
i don't know how standard the part is, but i'd had to try and find one.
AmperSand
Re: MA61 gearbox to speedo cable elbow Thu, 18 September 2003 03:05 Go to previous messageGo to next message
Yes the speedo cable does screw straight in.
I just did all of this with my 88 Supra (GA70) with 1JZ conversion.
The part is the same throughout the auto/manual boxes.
I got a new one from toyota because i simply couldnt find one at the wreckers, ended up costing me $130.
The cable does however screw directly in, unsure of how long that would last tho.
SupraBOY
Yeppoon/Rockhampton
Re: MA61 gearbox to speedo cable elbow Thu, 18 September 2003 03:21 Go to previous messageGo to next message
i've been going a year with it like that. never had a prob.
7mgte83
Barossa valley SA
Re: MA61 gearbox to speedo cable elbow Thu, 18 September 2003 06:56 Go to previous messageGo to next message
Ill give it a go if I can unscrew the old peice out of the gearbox, the thing's a tight as a nuns nasty.
does anyone know approximatly what year the 7m powered cars swapped from a speedo cable to a sensor? It's not really important but then Ill have some Idea what year the 7m I've got was made.
7mgte83
Barossa valley SA
Re: MA61 gearbox to speedo cable elbow Thu, 25 September 2003 01:53 Go to previous message
I'm having trouble getting the speedo cable to start screwing on but I think it will work.
For anyone who is interested you can find the identical elbow on:
8/82-12/86 tercel AL2x, 6/83-12/86 corona ST141, and 9/80-4/85 cressida MX6x
Previous Topic:18rc exhaust manifold or extractors
Next Topic:hatch spoiler for T-18
Current Time: Tue Nov 24 01:22:17 UTC 2026
Total time taken to generate the page: 0.0055079460144043 seconds
