Toymods » Tech & Conversions » T-18 2tg conversion legalities
gearb0x
T-18 2tg conversion legalities Tue, 16 September 2003 14:27 Go to next message
Hey
Im looking at the possibility of a 2tgeu conversion into my T-18 using pretty much everything needed from a te71... tank, wiring, computer and all that.. i dont think the front brakes are any different but for some reason the donor car is missing the diskbrake rear end (maybe it never even had one)
i was just wondering, if anyone knows acording to victorian laws how hard it will be to get registered?
Thanks,
Phill
Re: T-18 2tg conversion legalities Tue, 16 September 2003 14:33 Go to previous messageGo to next message
T-18's had 3T? so 2T is decrease in capacity, AND you are going to a fuel injected motor???
man the authorities are gonna love you Very Happy
shouldn't be hard at all, even in NSW!!!
call an enginer in the morning.. you'll prolly have to have it certified, unless it was an option??
Good luck Smile
gearb0x
Re: T-18 2tg conversion legalities Tue, 16 September 2003 14:38 Go to previous messageGo to next message
afaik the T-18 never came with 2t engines
but the TE71 is basically the same car sharing the same floorpan hence everything swapping over, the car has the same interior and dash and all that only dif is really the angle of the hatch. And different front panels, but they are also a straight swap
I cant see it being any real problem.. just wondering do i need enginners cert (im not fabricating anything?) or some check by someone..
[Updated on: Tue, 16 September 2003 14:44]
Re: T-18 2tg conversion legalities Tue, 16 September 2003 15:24 Go to previous messageGo to next message
T-18's are TE-72's ????(please forgive my ignorance of new cars)
i think you have a pretty strong case if you say that the TE-71 came with XXX and since the TE-72 is just a different body style, but essentially the same car, then it is pretty much just 'updating' the engine to a more modern motor that came in the same car!!
the only reason i thought maybe a cert was for the high pressure fuel lines, and even then, since it's all stock, it'd be dead easy..
check with your RTA equiv, then contact a couple of engineers and ask them if it is absolutely necessary to have it certified... it might make it easier if you get pulled over tho..
but then again, you lucky buggers don't have yearly inspections
should be easy, but get something in writing from your RTA first, so you have something to fall back on..
[Updated on: Tue, 16 September 2003 15:26]
Jonny2TG
Tasmania
Re: T-18 2tg conversion legalities Wed, 17 September 2003 11:20 Go to previous message
I know in Tasmania you can do this conversion without any engineering certificate or anything. You only need to change the engine number with transport. And maybe have a $20 inspection to verify the new engine number and general roadworthy of the change. Nothing special. I know with my KE35, and can fit any Toyota engine up to 1600cc. Only need better shocks and front brakes of a cirtain diameter (not very big).
If it was me, I would only change the engine number on your rego. Tell them its basicaly the same engine (which it is).
Previous Topic:Head gasket for 1ggte
Next Topic:DIY Turbo External Wastegate using intake valves!!!! they look great!!
Current Time: Sat Oct 24 20:11:58 UTC 2026
Total time taken to generate the page: 0.062257051467896 seconds
