Toymods » Tech & Conversions » 4age idleing problem
cam_RA40
Launceston, Tasmania
haha, funny little head!
4age idleing problem Wed, 17 September 2003 01:25 Go to next message
No Message Body
[Updated on: Mon, 05 July 2004 08:23]
FKN16V
NSW, East Coast
Re: 4age idleing problem Wed, 17 September 2003 02:33 Go to previous messageGo to next message
Try cleaning the throttle body with good quality carby cleaner, chances are your throttle is stuck open alittle bit.
Does the car blow smoke, if so what colour.
Just my 2c worth
cam_RA40
Re: 4age idleing problem Wed, 17 September 2003 03:26 Go to previous messageGo to next message
the car did blow a little white smoke/steem although that seems to have stopped since i put a 2" high flow straight through muffler on???
waynewatson
Re: 4age idleing problem Wed, 17 September 2003 05:31 Go to previous messageGo to next message
mine also seems to have 3 idle speeds: 2k, 1500, 800.
yours seems to stay too high for way too long, it should drop down as soon as the engine warms up.
frank_grimes
Re: 4age idleing problem Wed, 17 September 2003 05:44 Go to previous messageGo to next message
i had a similar problem a while back..
i didn't even notice but the little idle return spring had gone a stray..
NVD05X
parra
Re: 4age idleing problem Wed, 17 September 2003 09:41 Go to previous messageGo to next message
mine idles at 2800 for about 10 mins and then drops to 900
IRA11Y
Club Member
Re: 4age idleing problem Wed, 17 September 2003 10:50 Go to previous messageGo to next message
if the idle screw is turned all the way down then something is faulty, it should be at least 1.5 turns up
cant be bothered writing this for the hundredth time so just click the link....
common idle problems
manipulate
Re: 4age idleing problem Wed, 17 September 2003 11:19 Go to previous messageGo to next message
OK kick me if im wrong but wouldnt this just be the cold idle ?
and also seeing as though 2 other ppl have a very similar "problem" i would think even more so that its just the cold idle
and 10 minutes sounds about right as most cars take 10 minutes to reach Operating Temp when left idling....but it should be much less if your actually driving it
am i wrong ?
mrsoopra
Re: 4age idleing problem Thu, 18 September 2003 03:30 Go to previous message
I have a 100kw 4AGE small port in an AE86.. First start when its cold gives an idle of about 2,000rpm.. after about 2 minutes of idling it will drop to about 1,500 for another 5 mins or so, then drops to 950.. All 4AGE's i've seen do this. Although yours seems to take a bit longer.. Is your thermostat working correctly? On the 100kw (not sure about other 4AGEs) the cold idle is controlled by a wax pallet in the throttle body (water lines run into it), so the engine will continue to fast idle until the water temp rises to op temp..
When i did my conversion with this engine, i found it idled around 2,600rpm for a LONG time, found that the gasket inbetween the throttle body and the plenum was damaged and leaking. Might be worth replacing that?
Gaz
AE86 Trueno
Previous Topic:1uz manual and sump fitment
Next Topic:sw20 3sge extractors?
Current Time: Thu Nov 19 09:36:41 UTC 2026
Total time taken to generate the page: 0.0075979232788086 seconds
