Toymods » Tech & Conversions » (electrical) gze starter motor Question
twincam_ke20
Castlemaine Vic
icon5.gif  (electrical) gze starter motor Question Wed, 17 September 2003 08:59 Go to next message
How many volts should there be running from the ignition to the starter motor?
I currently have 7.1v, does this sound right, or enough to through the solenoid out?
Edit: If thats not enough volts, how do i fix this problem what needs to be done?
[Updated on: Wed, 17 September 2003 10:58]
twincam_ke20
Castlemaine Vic
icon5.gif  Re: (electrical) gze starter motor Question Thu, 18 September 2003 11:44 Go to previous messageGo to next message
BUMP Very Happy
sideshow
Re: (electrical) gze starter motor Question Thu, 18 September 2003 12:18 Go to previous message
well first measure the battery voltage
then measure the voltage at the solenoid
u should not drop more than 1 volt
even 1 volt is bit too much
if u ae gettin about 1 or more volts drop between battery and solenoid then fit a relay
straight from the battery then use the original starter solenoid wire to trigger the relay
the relay will then switch battery power to the starter solenooid
if u r droppin alot of volts u have a bad ignition switch or a bad connection somewhere
Previous Topic:exhaust header wrap tape stuff
Next Topic:Stainless or Not?
Current Time: Thu Nov 19 05:12:20 UTC 2026
Total time taken to generate the page: 0.006309986114502 seconds
