Toymods » General Car Talk » The clutch on my ma70
Caledwvech
icon10.gif  The clutch on my ma70 Thu, 18 September 2003 04:30 Go to next message
Well, I am a very happy person now! Turns out my clutch didnt need preplacing or anything. Took it into Pittwater Brake and Clutch specialists and they had a look at it, fixed the problem and phoned back to say they had fixed it. All within 6 hours. What is even better is that it cost me a big fat $0.
Thanks guys!
Very Happy Very Happy
Re: The clutch on my ma70 Thu, 18 September 2003 08:51 Go to previous messageGo to next message
What we'd *like* to know is what it was they fixed Razz
RobST162
Re: The clutch on my ma70 Thu, 18 September 2003 10:05 Go to previous messageGo to next message
The master cylinder had some adjustment thing? I don't know.. my car doesn't..
anyway, it was keeping pressure in the hydraulic system and keeping pressure on the clutch, so it was as if the clutch pedal was partially depressed all the time Sad
Re: The clutch on my ma70 Thu, 18 September 2003 14:16 Go to previous messageGo to next message
So it was a problem with the hydraulics? What a surprise!
Guest
Re: The clutch on my ma70 Thu, 18 September 2003 22:32 Go to previous messageGo to next message
so what is it about adjustment of master cylinders ?????
I am having some issues with my new clutch, and i think it is adjustment related.
Matt
Caledwvech
Re: The clutch on my ma70 Thu, 18 September 2003 23:07 Go to previous messageGo to next message
Basically he said that the master cylinder was "wound up" so that the clutch was half engaged the whole time. He just "wound it down" and works fine now. Cannot tell you the details sorry. He said it was like a five minute job though.
Re: The clutch on my ma70 Thu, 18 September 2003 23:29 Go to previous messageGo to next message
More than likely he was referring to the threaded adjustment on the master cylinder pushrod (ie the bit that goes between the clutch medal and master cylinder).
rob_RA40
c'town, NSW
Re: The clutch on my ma70 Fri, 19 September 2003 00:23 Go to previous messageGo to next message
any trick to adjusting these?
my CMS was leaking into cabin so i rebuilt it. now a few months later its leaking into cabin again. The bore looked good when i rebuilt it too.
could a badly adjusted CMS leak into cabin?
Re: The clutch on my ma70 Fri, 19 September 2003 00:27 Go to previous messageGo to next message
Nah, unlikely. It possibly had some minor pitting that might have gone unnoticed. Did you hone the bore before you rekitted it?
rob_RA40
c'town, NSW
Re: The clutch on my ma70 Fri, 19 September 2003 00:31 Go to previous messageGo to next message
hone is an affirmative.
i did notice one of the seals was damaged on the piston, when i replace the thing tomorrow ill see if the same seal is damaged again.
Re: The clutch on my ma70 Fri, 19 September 2003 00:34 Go to previous messageGo to next message
Check the bore carefully. Scrap it if there is any hint of pitting (you can bore and resleeve them, but given that you can buy them new from Repco....).
When fitting the new rubber, make sure you lube it with rubber grease (or if you are a bit of a cheapskate, some brake fluid) and hopefully this will prevent the seal from being damaged on reassembly.
[Updated on: Fri, 19 September 2003 00:35]
RobST162
Re: The clutch on my ma70 Fri, 19 September 2003 02:09 Go to previous messageGo to next message
Mine was leaking inside the firewall a while back. I was lazy and went to repco and just whacked a new one in there... Smile
Guest
Re: The clutch on my ma70 Fri, 19 September 2003 02:36 Go to previous messageGo to next message
i have adjusted that thread.
Would you think for a new clutch it shoudl be wound all the way down or up ?? i wound my pedal down and it seemed better.
Matt
Re: The clutch on my ma70 Fri, 19 September 2003 04:34 Go to previous messageGo to next message
That in cabin threaded rod simply adjusts how much free play the clutch pedal has. There should be 1-2 cm (or whatever the manual states) of free play at the pedal before the clutch starts to disengage.
7M-Brisbane
Re: The clutch on my ma70 Wed, 24 September 2003 12:41 Go to previous messageGo to next message
It is about now that I should be saying "I told you so" and you should be saying "thankyou" Very Happy
Caledwvech
Re: The clutch on my ma70 Wed, 24 September 2003 23:13 Go to previous message
Yeah mate, I think so. I think my "new car" paranioa (sp???) got the best of me. Very Happy
Previous Topic:Where are good window tinting places in Sydney?
Next Topic:Quick Question
Current Time: Thu Oct 22 11:55:58 UTC 2026
Total time taken to generate the page: 0.0057270526885986 seconds
