Toymods » Tech & Conversions » EFI Upgrade on 4AGE
ae86trueno
EFI Upgrade on 4AGE Thu, 18 September 2003 07:11 Go to next message
ok im looking into getting an aftermarket efi system, i know motec are the best so lets not start that discussion here.
What i really want to know is what else do i need to change over to lets say a Microtech LTX8 or on my 4AGE.
What sould i use as the input trigger, can i get the current distributer modified or am i better of using another type of trigger if running sequential ignition?? am i going to need anything else ??
Im a newbee when it comes to the electron side so anyone's help grateful
Ben
AE86 Trueno 4AGE.
Grega
melbourne.victoria.austra...
Re: EFI Upgrade on 4AGE Fri, 19 September 2003 07:23 Go to previous messageGo to next message
my understanding is that the microtech mt/ltx8 will trigger off the 4 tooth rotor in the early type dizzy and the later type 100kw variety can be modified for it.
you could also look at a haltech ECU or wolf - i believe these can also run off the factory dizzy.
Henn
Rosanna, Melb
Re: EFI Upgrade on 4AGE Fri, 19 September 2003 07:36 Go to previous messageGo to next message
Wolf V4 can definitely be set up with a coil negative trigger. gimme a yell if you want details.
IRA11Y
Club Member
Re: EFI Upgrade on 4AGE Fri, 19 September 2003 07:41 Go to previous messageGo to next message
hey Ben pop over to my new place (even closer to you now) and ill show you some information that might help you understand it a little better
ae86trueno
Re: EFI Upgrade on 4AGE Fri, 19 September 2003 10:29 Go to previous messageGo to next message
Thanks for the info guys, My 4AGE is a bigport, so by the sounds of it that will make things easier. The other ECU i had in mind was a Wolf V4, as they are both priced about the same, so thats good to hear, ill give you a buzz Henn if i decide on the Wolf instead of the Microtech.
Hi Micheal ill take you up on that offer ill give you a call next week and well sort something out, i have a nother race on sunday at Oran Park, so im a litle busy this weekend.
Ben
AE86 Trueno 4AGE
10sec_rx7
Syndey
Re: EFI Upgrade on 4AGE Wed, 24 September 2003 22:37 Go to previous messageGo to next message
the microtech will run off the 4 tooth trigger in the car perfectly, i have set a heap of these up and they work a treat and really give the motors a kick in the butt, the microtech will work with all the 4age pickups, weather it is 86kw, 100kw, 20v or GZE,
Dale
pro_ke
adelaide
Re: EFI Upgrade on 4AGE Thu, 25 September 2003 11:56 Go to previous messageGo to next message
someone on here has a LTX12 for sale for almost 1/2 retail! BUY BUY BUY
ab
10sec_rx7
Syndey
Re: EFI Upgrade on 4AGE Thu, 25 September 2003 22:08 Go to previous message
LTX12 retails at $1495,
so anything under $800 is a bargin, you will need to factor $200 for reprogramming to suit the 4age,
Dale
Previous Topic:Best Material for airbox construction?
Next Topic:TA22 fiberglass guards
Current Time: Thu Nov 19 19:08:42 UTC 2026
Total time taken to generate the page: 0.091678142547607 seconds
