Toymods » Tech & Conversions » 6mge front main oil seal
Cressida Supra
6mge front main oil seal Thu, 18 September 2003 14:39 Go to next message
is this the same as a 7mge seal? as i was once told?
or is it the same as the 5m's?
can i just pop the crank pulley off to change it? or is more involved? (ie motor/crank out)
Re: 6mge front main oil seal Thu, 18 September 2003 22:16 Go to previous messageGo to next message
You need to get the crank pulley, timing covers, timing gear (and possibly even the oil pump gear) off to service that. I'm pretty sure the crank timing gear needs an SST to get it off. Failing that a gear puller should do the trick. You'll definitely want to get the radiator out just to give yourself more room and prevent damaging a core.
EDIT: Here you go.
http://www.cygnusx1.net/supra/library/TSRM_MKII/em/EM_013.gif
[Updated on: Thu, 18 September 2003 22:18]
supra1978
Re: 6mge front main oil seal Thu, 18 September 2003 22:49 Go to previous messageGo to next message
Probably the hardest part of this job is removing the crank-pulley bolt! You'll need plenty of leverage (unless you own a mighty rattle gun). The rest of the job is easy. Definitely need a gear puller for the crank-pulley. You might be lucky with the timing gear; sometimes they slide off the crank by hand. (No need to remove any other timing gear.)
Use a 7MGE seal. Check the fit of the seal on the timing gear. You might need to shorten the coil spring on the inside of the seal to ensure it will be oil tight.
Re: 6mge front main oil seal Thu, 18 September 2003 23:21 Go to previous messageGo to next message
Thanks supra1978. I wasn't 100% certain about the oil pump gear (I have actually never done one on a 5/6MGE so I just wasn't sure).
Cressidasupra, make sure you do the crank pulley bolt up tight. On the 5/6MGEs, they have a habit of becoming slightly loose, causing the crank pulley to be loosely secured, with subsequent chewing out of the Woodruff key and respective slots in the crank and pulley. Apart from making the setting of ignition timing impossible, it could render the crank unrepairable if left for long enough!
[Updated on: Thu, 18 September 2003 23:22]
ed_ma61
Lost in the K hole
Re: 6mge front main oil seal Fri, 19 September 2003 06:58 Go to previous messageGo to next message
yeah, timing pulley should come off reasonably by hand (wd or penetrating oil is helpful)
from memory, the crank pulley on the 6m needs something like 280-300Nm tourque on fastening!!
Cressida Supra
Re: 6mge front main oil seal Fri, 19 September 2003 07:03 Go to previous messageGo to next message
is that the same as the 5m torque? or more? same as 7m?
dingaling
tas
Re: 6mge front main oil seal Fri, 19 September 2003 14:43 Go to previous messageGo to next message
crikey, am i going to have to do all of this when i change my valve seals? i thought to get the cam covers off was abit simpler, remove the 3000pipe, remove the coil pack, remove the throttle linkage and then your there.
Re: 6mge front main oil seal Fri, 19 September 2003 14:56 Go to previous messageGo to next message
um
lemme guess, it's gonna be that hard to change my 1jz one?
Cressida Supra
Re: 6mge front main oil seal Fri, 19 September 2003 15:15 Go to previous messageGo to next message
dingaling wrote on Fri, 19 September 2003 22:43
yes, you can do it the dodgy way like that, but chances are that if you have to replace the valve stems seals, then some of the valve guides have gone too
i had the VSS's replaced when i bought my 6M (40k kms ago), and i just did them again (guides mainly this time) a few months ago
had the guides been done when i bought the motor, i would not have to have spent the $500 to do them this time around
i strongly suggest doing the head properly
taking it off, completely stripping it, and rebuild
btw, we actually think it was the oil pump pulley seal that was leaking, not the crank pulley seal
Cressida Supra
Re: 6mge front main oil seal Fri, 19 September 2003 15:19 Go to previous messageGo to next message
supra1978 wrote on Fri, 19 September 2003 06:49
actually the timing gear pulley was the hardest of the lot, we actually needed a puller to get it off, although it did only take 10 secs
the crank bolt was easy, just brace a breaker bar against the chassis, and crank the motor over once. easy
and the crank pulley actually can off by hand!! NO force was needed
Re: 6mge front main oil seal Fri, 19 September 2003 19:25 Go to previous messageGo to next message
If that's the case I would check the crank and pulley keyways to make sure they are not damaged.
ed_ma61
Lost in the K hole
Re: 6mge front main oil seal Sat, 20 September 2003 07:04 Go to previous messageGo to next message
Cressida Supra wrote on Sat, 20 September 2003 01:15
thats not a dodgy way of doing it... thats exactly how youd do it if all you wanted to do was to replace the VSS's.
as for replacing the guides? youd be amazed at the durability of the toyota guides, and the acceptable wear limits the guides offer. eg: the 7m head im using has over 240000km on it, and the original guides have less than half the wear as speccd in the tolerances. the tolerances are VERY generous. unless something has gone rather astray in the engine, or if you had suspicions a guide was worn, id not bother.
ed_ma61
Lost in the K hole
Re: 6mge front main oil seal Sat, 20 September 2003 07:05 Go to previous messageGo to next message
dingaling wrote on Sat, 20 September 2003 00:43
no Smile
Cressida Supra
Re: 6mge front main oil seal Sun, 21 September 2003 08:46 Go to previous messageGo to next message
gianttomato wrote on Sat, 20 September 2003 03:25
yeah, checked em while it would out, and they were in perfect condition
Re: 6mge front main oil seal Sun, 21 September 2003 13:26 Go to previous message
Damn, that makes the 1G look positively simple Razz
Previous Topic:Superchargers from 1G onwards
Next Topic:Lexus IS200 6 speed gearbox
Current Time: Thu Nov 19 22:33:17 UTC 2026
Total time taken to generate the page: 0.0064189434051514 seconds
