Toymods » Tech & Conversions » Suspension gurus needed !
Les
icon1.gif  Suspension gurus needed ! Thu, 16 May 2002 14:01 Go to next message
Ok what is a good suspension package to get ?
I want the car slightly lower... proly an inch & half will do me fine... the sump and exhaust sits pretty low as is.. (Max if you are reading this, is your sump pretty close to the ground ?)
with shocks - what do you recommend ?
and what about camber kits and shit like that ?
and what do "nolathane bushes" do for your car ?
ed_ma61
Lost in the K hole
Re: Suspension gurus needed ! Thu, 16 May 2002 14:10 Go to previous messageGo to next message
nolathane bushes... simply replaces your (most likely) very tired existing bushes that sit b/w rigid body structures and moving parts of the suspension system such as link pivot points and swaybar mounts.
replacing these bushes revoves any 'slop' from the joint, and basically tightens up your suspension movement, so it only travles in the direction its supposed to under load.
nolathane is simply a very good replacemnt material to use when doing your bushes.
ed
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: Suspension gurus needed ! Thu, 16 May 2002 14:16 Go to previous messageGo to next message
Dude, mine is 2" lower and it never scrapes. My car still sits pretty high off the ground, even though the guards are almost covering the wheels!
As for shocks, it depends on what sort of damping you want... My shocks are ultra hard, but I like them like that... Need them like that really...
With the camber kit, talk to K-Mac. But I haven't really found a need for one... Not like I've been out on the track or anything...
Nolathane bushes minimise the movement of your suspension components... They may be a bit of overkill for the streets... Depends on how you drive...
I think I need them... I have a feeling that the rear end is getting very sloppy...
mr_messy
Re: Suspension gurus needed ! Thu, 16 May 2002 14:35 Go to previous messageGo to next message
dont nolathane bushes have a shorter life compared to the rubber bushes?...like they only last around a yr or something like that
i think i read that somewhere...
so if you dont want to keep replacing them..just use the rubber ones...
thats my unqualified piece of advice
Les
Re: Suspension gurus needed ! Thu, 16 May 2002 22:54 Go to previous messageGo to next message
How silly am I - I will not take it to the track so no need for the camber kit... Freak
What i did forget was the rear sway bar and possibly strut brace.
Sounds good..
1) lower 1.5 - 2 inches
2) hard shocks
3) rear sway bar
4) strut brace (optional really)
will that get my car cornering pretty good or what ?
Oh also... my car does not really spin out too much when I give it... when I get stiffer suspension... will this be a more likely occurence... I feel as if that my very soft suspension is preventing the car from wheelspin...
[Updated on: Thu, 16 May 2002 23:14]
Nark
Cabramatta, NSW
icon1.gif  Re: Suspension gurus needed ! Fri, 17 May 2002 03:13 Go to previous messageGo to next message
You got a bigger front swaybar yet?
What about your wheels? What are they?
Soft shocks and springs do prevent wheelspin because they allow more weight to transfer to the back during acceleration.
Swaybars can cause more wheelspin in certain circumstances... Mainly when you're on bumpy ground.
Re: Suspension gurus needed ! Fri, 17 May 2002 04:08 Go to previous messageGo to next message
Les, do you have an RA60 or an RA65? IF you have an RA65, you'd probably have to watch just how far you lower the car because of the IRS. Someone covered this before on the old forums.
Narks RA60 lowered: || ||
Your RA65 lowered: // \\
These are views from your cars at the back.. If I were you, go talk to the Mk2 boys. They should have a clue as to what to do as well. I read somewhere they dont recommend lowering the car more than 1.5" or something and I'd reckon it would be a similar story for an RA65.
Alternatively go speak to a suspension specialist and run through with them exactly what you are looking for.
Les
Re: Suspension gurus needed ! Fri, 17 May 2002 07:06 Go to previous messageGo to next message
Max have you only got a front swaybar - or have you also got a rear one... ?
which would you recommend I get ?
only the front sway bar is available from Whiteline - for $299...
Nark
Cabramatta, NSW
icon3.gif  Re: Suspension gurus needed ! Fri, 17 May 2002 07:56 Go to previous messageGo to next message
I have a larger front swaybar.. Rear one is stock (ie: tiny).
I wouldn't mind a larger rear one, but not too sure how it'd affect the handling, it's already tail happy enough. It might be too much of a handful if I upgrade the rear swaybar.
As to which one you should get, it's up to what you want your car to handle like...
Re: Suspension gurus needed ! Fri, 17 May 2002 11:20 Go to previous messageGo to next message
Yeah...do you just want something a little harder and firmer for the occasional spirited driving....or something a little firmer again...with good balance across most road surfaces...or something verging on drift style where its really hard...ala Nark Evil or Very Mad
Les
Re: Suspension gurus needed ! Fri, 17 May 2002 13:10 Go to previous messageGo to next message
Just want it to feel a little less like a boat..basically a firmer package, not so much for daytona'ing.. like Max
whats the diff between a rear sway bar and a front one anywayz ppls ?
Nark
Cabramatta, NSW
Re: Suspension gurus needed ! Sat, 18 May 2002 14:22 Go to previous messageGo to next message
If you want something slightly firmer, drop it an inch and get slightly firmer shocks. It will improve the boatiness noticably.
Don't worry about sway bars and the like.
In regards to the swaybars, in a nutshell:
Arrow Front swaybar will reduce oversteer.
Arrow Rear swaybar will reduce understeer..
Flem
cambo
Re: Suspension gurus needed ! Tue, 21 May 2002 10:04 Go to previous message
add to your list neg 1.5 deg each side for camber and 1.5mm a side for toe in.itll chew your tyres like but itle handle well.
Previous Topic:FORD STUD RA40
Next Topic:HELP What do i need to change
Current Time: Wed Nov 18 04:32:35 UTC 2026
Total time taken to generate the page: 0.0053470134735107 seconds
