Toymods » Tech & Conversions » Clutch Cable ....HELP !!!
86racer
Clutch Cable ....HELP !!! Mon, 15 July 2002 13:00 Go to next message
I've noticed when I put my 100KW 4age into my sprinter the clutch cable will get in the way of exhaust pipe...
so I just want to get an idea what would be the most effective set up ...any info would appreciated ...
Re: Clutch Cable ....HELP !!! Tue, 16 July 2002 00:02 Go to previous message
From what I can assume, you've got one of two problems:
1. You've actually got an AE85 that had a clutch cable in the first place. Get a hold of an ae86 hydraulic clutch cable set up and use that
2. You've already got a hydraulic clutch (more than likely), but you're concerned about it being on the exhaust side. Just be careful whereabouts you route the exhaust pipe (not too close!), use a heat shield and get a braided steel hydraulic hose made up from Pirtek or similiar. As long as the pipe isn't actually touching the clutch cylinder (or unreasonably close), you shouldn't have much to worry about.
Previous Topic:Some Questions
Next Topic:5S-FE turbo kits
Current Time: Sat Oct 17 03:02:08 UTC 2026
Total time taken to generate the page: 0.0044469833374023 seconds
