Toymods » Tech & Conversions » 18RG Rings question.
azzsaccRA23
Hobart, TAS
18RG Rings question. Fri, 19 September 2003 11:08 Go to next message
I want to put new rings in my 18rg and i was wondering if rings for a 18R or 18R-C are the same or will they work or do i need to get rings specific for 18RG.
[Updated on: Fri, 19 September 2003 11:10]
M.J.H
Re: 18RG Rings question. Fri, 19 September 2003 12:41 Go to previous messageGo to next message
Rings are specific to piston dia and the size of the lands.
So if you had an 85mm piston with 1.5,1.5,3.0 mm lands than any ring set the same will fit wether they are toyota,nissan,holden etc.
But all 18r pistons are the same size as far as i know.
Hope this helps.
earlyrolla
Re: 18RG Rings question. Mon, 22 September 2003 02:27 Go to previous messageGo to next message
18R and 18RG have the same bore size BUT different piston ring thicknesses, so you will need to buy the 18RG rings. Also when I bought my 18RG rings (genuine Toyota) the top ring was cro-moly and the second ring was cast.
As M.J.H. said, if you know your bore size and ring thickness you could get the ringhs to suit. Save buying genuine $$$. Make sure if you get 'file fit' rings that they are fitted properly (i.e. actually filed to size).
Mr DOHC
Re: 18RG Rings question. Mon, 22 September 2003 10:57 Go to previous messageGo to next message
when i got my new rings the box said all these engines liek 12r 8r and 18R 18RG 19RGU 18RGEU ect they were non gen
Re: 18RG Rings question. Mon, 22 September 2003 11:35 Go to previous messageGo to next message
this may not apply to the 18RG, but there can be differences in the depth of the ring grooves, and thus the depth of the rings...
had this happen with a K motor.... 2 different depths of oil rings were released..
azzsaccRA23
Hobart, TAS
Re: 18RG Rings question. Tue, 23 September 2003 09:45 Go to previous messageGo to next message
The engine workshop i went to were pretty sure 18r rings would be right so i bought them, got home and discovered there wrong because i have 40thou oversize ARIAS pistons, i will go back to engine workshop, does anyone know about these pistons or what i should do.
Steve M
Re: 18RG Rings question. Tue, 23 September 2003 12:09 Go to previous message
THERE IS ANOTHER DIFFERENCE between 18r and 18rg's
18rg's are built to go to around 8000 rpm, 18r's are not.
Hence, 18rg owners are usually advised to go for chrome rings, as the normal type rings can warp at high revs and high cylinder temps, this ends in tears.
Previous Topic:jza80 misbehaviour - keeps stalling, boosts badly, makes weird noises and uses stacks of petrol
Next Topic:Climate control on ST185
Current Time: Fri Nov 20 06:50:39 UTC 2026
Total time taken to generate the page: 0.0044398307800293 seconds
