Toymods » Tech & Conversions » 2jz sparks
2jz sparks Fri, 19 September 2003 13:11 Go to next message
just wondering what plugs I should put in a mate's 2jz... would the 1jz ones be suitable? (BKR6e)
Soarer
Wollongong
Re: 2jz sparks Sat, 20 September 2003 02:48 Go to previous messageGo to next message
I believe they use the same plugs as the 1JZ, so BKR6E should be fine.
wastegate
Gold Coast
Re: 2jz sparks Sat, 20 September 2003 14:35 Go to previous messageGo to next message
stock gap for the 2J is 1.2mm 1J is 0.8mm
Re: 2jz sparks Sat, 20 September 2003 15:03 Go to previous messageGo to next message
ta - forgot to ask about the gap Smile
manipulate
Re: 2jz sparks Sun, 21 September 2003 00:40 Go to previous messageGo to next message
different gap = different plug
Re: 2jz sparks Sun, 21 September 2003 04:52 Go to previous messageGo to next message
alrighty - so any ideas on what a 2jz might take?
repco dont stock "sparks for imports", although I have a feeling they wouldn't know if they had a compatible one in there.
we're at baulkham hills at the moment - so anywhere nearby (like parra) that stocks them would be good.
I've pulled off the coil packs already, so I'm not really keen on putting it all back together for another day
Stenno
Re: 2jz sparks Sun, 21 September 2003 07:21 Go to previous messageGo to next message
draven wrote on Sun, 21 September 2003 14:52
Toyota ND's - if you can get trade, $11 each, They're also used in the the V6 Camry.
This a GTE or GE?
If it's a GTE, regap them to .8mm otherwise you *might* blow out the spark at 14psi and above.
manipulate
Re: 2jz sparks Sun, 21 September 2003 08:01 Go to previous messageGo to next message
everyone put this in there favourites to find NGK plugs for their desired engine
http://www.ngkspark.com.au/
go to the top right and click the drop bar thing
choose passenger vehicles
obviously choose toyota , then supra
however it doesnt have any of the JZ series
only the M series supras
so what other cars come with the 2JZ ?
ill try and see if we got it listed at work tomrorow if i rememeber
also i just found out it has a cross-reference from other products to NGK but not the other way round
[Updated on: Sun, 21 September 2003 08:04]
manipulate
Re: 2jz sparks Sun, 21 September 2003 08:28 Go to previous messageGo to next message
k i found a better one
http://www.ngksparkplugs.com/apps/car_truck_suv/de fault.asp?nav=60000&country=
what yr model 2jz-gte is it Greg ?
Re: 2jz sparks Sun, 21 September 2003 08:55 Go to previous messageGo to next message
ended up getting the BKR6EP-11 , which is the stock platinum plug
bit pricey, but repco stock was a little limited.
gapped to 1.1, so hopefully wont be misfiring
edit: this info was gratefully taken from www.mkiv.com Smile
[Updated on: Sun, 21 September 2003 08:55]
Soarer
Wollongong
Re: 2jz sparks Mon, 22 September 2003 09:58 Go to previous message
Is the engine modified in any way ? The platinums are fine for a totally stock engine, but tend to break down rather easily with even minor mods. Just changing the exhaust on my 1JZ chewed out a set of platinums quickly.
Best bet are still the steel/copper plugs, but you already have the platinums now Sad
Previous Topic:5sfe to 3sgte conversion in celica
Next Topic:TA22 lowerd springs
Current Time: Sat Oct 24 09:42:08 UTC 2026
Total time taken to generate the page: 0.0061559677124023 seconds
