Toymods » Tech & Conversions » TVIS
CS3086
Denmark
TVIS Sat, 20 September 2003 18:09 Go to next message
Hey again
Should I disconnect the TVIS option?
Jacob
RobST162
Re: TVIS Sun, 21 September 2003 01:42 Go to previous messageGo to next message
nah it rocks! It does make a difference, sorry to say this, but just search around here... there have been some rather lengthy discussions on the topic around.. hahah But basically the conclusions were it does help!
spectral
Re: TVIS Sun, 21 September 2003 03:10 Go to previous messageGo to next message
On a mostly stock engine it does help increase low RPM torque by increasing the air flow speed into the combustion chamber. On a high power engine it could become a restriction. If, for example you had stroked the engine to 2.2L or similar, then you'd probably ditch the TVIS as the stroker crank would make up the lost torque.
If you do decide to ditch it, then I'd do it properly and take off the intake manifold and the TVIS plate (sits between the intake manifold and the head) and actually take out the butterflys. That way you are truly removing the restriction, rather than just disconnecting it.
RWDboy
Re: TVIS Sun, 21 September 2003 07:43 Go to previous messageGo to next message
I think someone really needs to write something permanent up on this. It seems to crop up quite often!
It makes me wonder how much bad press the T-VIS got though, alot of people are under the impression that Toyota (Yamaha designed tho) put it on there to make the engine perform *worse* (which is obviously bs)
RWDboy
Re: TVIS Sun, 21 September 2003 07:48 Go to previous messageGo to next message
Oh - and one other thing...it's mainly on there due to bad (or should I say innefficient) port design, and you'd have to increase the stroke by *alot* (not just out to 2.2 litres) in order to gain a real benefit from taking off T-VIS...you would probably find it's not physically possible to stroke out the engine far enough to gain benefit from no T-VIS.
Once again, it really comes down to the design of the head and manifolds (port size, valve lift and duraction, intake manifold length etc)...and this has been covered before.
gabe
Re: TVIS Sun, 21 September 2003 08:38 Go to previous messageGo to next message
FWDboy wrote on Sun, 21 September 2003 15:48
I dont agree..... 3S-GTE heads flow extreamly well from the factory. 3S-GTE heads do not have innefficient port design
mrsoopra
Re: TVIS Sun, 21 September 2003 08:43 Go to previous messageGo to next message
Leave TVIS on for near stock (ie not HEAVILY modified) engines. Check bill sherwoods page. Heaps of info there Cool http://www.billzilla.org/4agstock.htm
RWDboy
Re: TVIS Sun, 21 September 2003 15:01 Go to previous messageGo to next message
Flow isn't the issue, it's streetable engine torque curve and streetable emissions that I'm assuming we are talking about. Of course, turbo and NA have different needs, so I guess in that regard the 3S-GTE/4A-GZE 'flows' quite well ... as opposed to the 4A-GE and 3S-GE.
CS3086
Denmark
Re: TVIS Sun, 21 September 2003 20:28 Go to previous message
Thanks for all the answers
Jacob
Previous Topic:Really bad fuel consumption from my 4AGE??
Next Topic:Superchargers from 1G onwards
Current Time: Fri Nov 20 00:50:23 UTC 2026
Total time taken to generate the page: 0.0050821304321289 seconds
