Toymods » Tech & Conversions » 2J water temp sensor location?
BlackSupra
2J water temp sensor location? Sat, 20 September 2003 23:24 Go to next message
Norbie or GT, or anyone else!
Where is the 2J water temp sensor on the block?
ta guys!
oh and im having this much Shocked fun Smile
Re: 2J water temp sensor location? Sun, 21 September 2003 00:00 Go to previous messageGo to next message
They are located in the head. The one for the EFI is located below and between the intake runners for cylinder 1 & 2, whilst the sender for your temp guage is located directly below the intake runner for cylinder number 2.
Stenno
Re: 2J water temp sensor location? Sun, 21 September 2003 07:26 Go to previous messageGo to next message
gianttomato wrote on Sun, 21 September 2003 10:00
Dave,
On the GTE these senders are in different locations than the GE by the looks of things.
Gauge sender is located on the water outlet pipe, it's the single wire plug.
The ECU sender is the twin wire plug which is located next to the gauge sender.
Re: 2J water temp sensor location? Sun, 21 September 2003 07:30 Go to previous messageGo to next message
Stenno, you are absolutely right! However, I have the inside scoop - Black Supra has a 2JZGE in his MA61. Very Happy
BlackSupra
Re: 2J water temp sensor location? Mon, 22 September 2003 01:29 Go to previous messageGo to next message
Just wondering if you could email me / post a pic of its location from the 'sensor location' diagram.
Im pretty sure i tapped into the sensor wire and not the sender.
Re: 2J water temp sensor location? Mon, 22 September 2003 03:36 Go to previous messageGo to next message
Here is a pic.....sorry about the crappy nature.
http://members.optusnet.com.au/gianttomato/Toyota%20Power%20/water%20temp%20sensors.jpg
BlackSupra
Re: 2J water temp sensor location? Tue, 23 September 2003 02:44 Go to previous message
Found and wired up Smile
Working temp gauge Very Happy , ta guys, it would appear at ambient temps lastnight of approx 23 degrees the car remains perfectly in the middle of the temp gauge.
Will have to see what happens when summer and heat soak sets in Confused
Previous Topic:Lift pump without Surge tank for EFI
Next Topic:Sprinter gearbox and diff oils
Current Time: Fri Nov 20 09:23:20 UTC 2026
Total time taken to generate the page: 0.0047869682312012 seconds
