Toymods » Tech & Conversions » RT142 Corona diff
RT142 Corona diff Mon, 22 September 2003 02:33 Go to next message
Hi all,
I spent Saturday scrounging at the wreckers, mostly looking for an RA65 so I can steal its diff. I didn't have any luck, however I did find an RT142 Corona which has the same 22R-E engine as the RA65 and the IRS setup looks identical as well. This leads me to believe that the diff may also be the same (ie 3.5:1 F series), BUT there was no axle code on the build plate! Sad
So my question is, does anyone know what diff type/ratio is found in an RT142 with an automatic transmission? I'm getting desperate for a 3.5:1 diff but I don't want to fork out $200 for this one only to discover it's a T series!
Re: RT142 Corona diff Mon, 22 September 2003 03:28 Go to previous messageGo to next message
Norbie... RT-142 corona's fit into two distinct categories AFAIK.
1/ Local made/built. Has craptacular live axle BORG WARNER grinding diff. Usually you find them with discs, but some have drums (like the ST-141 does)
2/ Fully imported (usually "Avante"). These have complete IRS F series rear end!!. Nothing IRS was made in australia by borg warner, and nor am i aware of a T series IRS....
If all else fails norbie, take a trip to your local library, and borrow a Corona workshop manual!
Re: RT142 Corona diff Mon, 22 September 2003 03:38 Go to previous messageGo to next message
Hooray, this is some good news! I still need to know the diff ratio though... any ideas?
Re: RT142 Corona diff Mon, 22 September 2003 03:44 Go to previous messageGo to next message
Only the magic books at the library can tell u that! Razz Cos i really don't know...
P.S. $200!?!?! faaarrrrrk. Can't u just tell them its from a 1984 corolla or something?
Re: RT142 Corona diff Mon, 22 September 2003 03:46 Go to previous messageGo to next message
As soon as they realise it's IRS, the price suddenly goes through the roof. Sad
cambelt
melb
Re: RT142 Corona diff Mon, 22 September 2003 08:45 Go to previous messageGo to next message
sa 63 have a t series irs diff set up.
Re: RT142 Corona diff Mon, 22 September 2003 11:11 Go to previous messageGo to next message
wow, thats cool Smile
c2888
Re: RT142 Corona diff Mon, 22 September 2003 12:20 Go to previous messageGo to next message
I usually look stuff up on Drive.com.au
they have neat details like power, weight, compression ratio, track, options adn final drive ratios.
Actually it's pretty comprehensive. Although it's not always accurate, like my infotech teacher said, garbage in, garbage out.
If it is a f-series you'll be smiling, i'll let you find out the ratio.
http://www.drive.com.au/buy/market_value/car_detai ls.asp?nvic=LC9&make=TOYOTA&model=CORONA&a mp;series=&year=1987&body=
You could probably buy a whole Corona for not much more than $200, just find one with a stuffed head gasket. Very Happy
V8_MA61
Re: RT142 Corona diff Mon, 22 September 2003 12:29 Go to previous messageGo to next message
norbie if you're right, and its a 3.5:1, im interested also!
Re: RT142 Corona diff Mon, 22 September 2003 13:37 Go to previous messageGo to next message
"Final Ratio 3.42"
Noice!
I reckon I'll be visiting that wrecker again on the weekend. If they don't want an arm and a leg for it, it's MINE ALL MINE!!
Bugman
Re: RT142 Corona diff Tue, 23 September 2003 01:45 Go to previous messageGo to next message
ok, according to my book that came with my car, a 2.4L sedans had the irs rear end. which to my knowledge is a F series. I've gotta take the cover plate off my diff to redo the seal there so I'll be counting and measuring etc when I do that, I also wanna know what gearbox is in the car, w55/57/58??
but the diff ratio has to be either 3.7 with a w58 or 3.5 with a w57/55 by my shoddy maths.
ddeane
PNG
Re: RT142 Corona diff Tue, 23 September 2003 02:28 Go to previous messageGo to next message
Gidday
Unless Toyota had different rear ends the diff for a rt141/2 is a BW 21 spline diff - no stronger than a T series.
Craig
rob_RA40
c'town, NSW
Re: RT142 Corona diff Tue, 23 September 2003 02:36 Go to previous messageGo to next message
the avante RT142 is imported, no BW gear on there
Re: RT142 Corona diff Tue, 23 September 2003 02:57 Go to previous messageGo to next message
yeah, like i said there are TWO types of RT-142's. The imported with the complete IRS F series, and the local with borg warner (Freak) live axle rear.
P.S. Bugman - you will have a W55 in there... looks the same on the outside as a W58 (and is) but has an alloy sandwich plate. Hence you'll have a 3.5 ratio!
Very Happy
Re: RT142 Corona diff Tue, 23 September 2003 03:11 Go to previous messageGo to next message
Bugman wrote on Tue, 23 September 2003 11:45
Ooh ooh ooh!! When are you planning to do this?
Re: RT142 Corona diff Tue, 23 September 2003 03:49 Go to previous messageGo to next message
I had the cover off an RA65 auto on the weekend....worked out to 3.7:1.
Re: RT142 Corona diff Tue, 23 September 2003 04:20 Go to previous messageGo to next message
Cool, didn't know the autos had a different ratio. I still can't find one though, auto OR manual. I had no idea these things were rare, but apparently they are!
Re: RT142 Corona diff Tue, 23 September 2003 05:49 Go to previous messageGo to next message
Do you just want it for the gearset?
Re: RT142 Corona diff Tue, 23 September 2003 10:38 Go to previous messageGo to next message
Yep! I need a taller ratio for the Supra, preferably 3.5:1 or 3.7:1, and no-one seems to sell them new so second-hand is my only option.
Bugman
Re: RT142 Corona diff Tue, 30 September 2003 03:51 Go to previous messageGo to next message
I plan on doing it this weekend (long weekend) depending on work g/f etc... my car is a manual 1985 avante
chubbylover53
Re: RT142 Corona diff Thu, 01 April 2004 04:07 Go to previous messageGo to next message
I have a 1986 corona CSi IRS with the 2.4L. Does any one know what diff is in it, as far as i was aware it had an IRS borg warner. i'm looking for a lsd to replace my old diff but i don't know what car i can get one out of. i want to kep it IRS with rear disc brakes.
Re: RT142 Corona diff Thu, 01 April 2004 04:36 Go to previous messageGo to next message
There is no IRS Borg Warner diff (not in Coronas anyway); if you have IRS it's a Toyota diff, and since you have the 2.4 litre engine if will be an F series diff, same as the RA65 Celica and MA61 Supra. LSD centres can be found second-hand or new; as a matter of fact there's currently a group buy for F series TrueTrac's, so you might want to get on board!
chubbylover53
Re: RT142 Corona diff Thu, 01 April 2004 04:44 Go to previous messageGo to next message
i'm interestd but what do you mean by group buy?
Re: RT142 Corona diff Thu, 01 April 2004 06:20 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&t h=31719&start=0&rid=90
V8_MA61
Re: RT142 Corona diff Thu, 01 April 2004 08:45 Go to previous messageGo to next message
norbie, how desperate are you...i might sell mine depending if i can find an xj12 lsd...
Re: RT142 Corona diff Thu, 01 April 2004 08:47 Go to previous messageGo to next message
Norbie wanted one in September Rolling Eyes He has a Truetrac remember?
V8_MA61
Re: RT142 Corona diff Thu, 01 April 2004 08:49 Go to previous messageGo to next message
doh...this is one damn old thread!
SeptemberSquallIndustries
Re: RT142 Corona diff Sun, 04 April 2004 03:28 Go to previous messageGo to next message
chubbylover: *insert thread mining smilie here*
AE86Trader
Central Coast
January 2005
Re: RT142 Corona diff Thu, 20 January 2005 09:50 Go to previous messageGo to next message
hey guys I am after a borg warner diff out of a corona that is disc brake rear..
Re: RT142 Corona diff Thu, 20 January 2005 12:00 Go to previous message
Really? That's great!
Previous Topic:Difficulty in rebuilding Power Steering pump
Next Topic:ST205 head on ST185 block question
Current Time: Sun Oct 18 21:04:51 UTC 2026
Total time taken to generate the page: 0.010439157485962 seconds
