Toymods » Tech & Conversions » 1uz sump pics
Cressida Supra
1uz sump pics Mon, 22 September 2003 05:03 Go to next message
any one got pics of a 1uz REAR sump? or even a FRONT sump?
i've got plenty of pics of MID sumps, but none of the other two
peewee
cambelt
melb
Re: 1uz sump pics Mon, 22 September 2003 08:42 Go to previous messageGo to next message
I need a pickup and windage tray for a crown mid sump if you want to sell those bits ,
the front sumps are ls400,cellsior
the rear sumps are uzz 30 series soarer
Cressida Supra
Re: 1uz sump pics Mon, 22 September 2003 08:57 Go to previous messageGo to next message
ummm...
i have always been under the impression that the front sumps were from crowns, and mid sumps from soarers?
Re: 1uz sump pics Mon, 22 September 2003 09:01 Go to previous messageGo to next message
Front sump: LS400, Crown Majesta, Aristo
Midsump: Crown Royal Saloon (by far the most common one)
Rear sump: Soarer
chrisss
melb
Re: 1uz sump pics Mon, 22 September 2003 09:05 Go to previous messageGo to next message
whats the dif b/w crown majesta and crown royal.
model codes, body shell etc.
Cressida Supra
Re: 1uz sump pics Mon, 22 September 2003 09:12 Go to previous messageGo to next message
whats the diff between an LS400 and a Soarer? (i know one is lexus, one is toyota)
chrisss
melb
Re: 1uz sump pics Mon, 22 September 2003 12:25 Go to previous messageGo to next message
if you dont know the difference b/w a lexus ls400 and a soarer you are totally blind.
both these cars are quite common on australian roads.
one is large sedan and the other a coupe.
Cressida Supra
Re: 1uz sump pics Mon, 22 September 2003 13:22 Go to previous messageGo to next message
yeah, i realised this later
i was actually thinking of the SC400, not the LS400
my mistake
Cressida Supra
Re: 1uz sump pics Mon, 22 September 2003 13:27 Go to previous messageGo to next message
so is this soarer mid? or rear sump?
coz it looks very mid to me
http://oz-enet.com.au/~peewee/1uz.jpg
[Updated on: Mon, 22 September 2003 13:29]
Re: 1uz sump pics Mon, 22 September 2003 14:10 Go to previous messageGo to next message
gianttomato wrote on Mon, 22 September 2003 19:01
Rear sump: Soarer
cambelt
melb
Re: 1uz sump pics Mon, 22 September 2003 14:16 Go to previous messageGo to next message
Soarer looks like a toe nail.
Cressida Supra
Re: 1uz sump pics Mon, 22 September 2003 14:28 Go to previous messageGo to next message
well f|_|ck
it looks like the idea of using a rear sump has just gone out the window
Cressida Supra
Re: 1uz sump pics Mon, 22 September 2003 14:58 Go to previous messageGo to next message
ok, let me clarify this before i go positively bonkers figuring it out
the rear sump and the mid sump are the same distance from the rear of the block but the mid sump is longer and thinner? as opposed to the rear that is shorter but wider?
i came to this conclusion by comparing the pic of the underside of the soarer, and that pic of the 1uz sump that GT posted the other day
PLEASE tell me if i am going crazy and seeing/dreaming things
Re: 1uz sump pics Tue, 23 September 2003 00:15 Go to previous messageGo to next message
I don't mean to be a pain but don't you need a front sump anyway? I'd imagine the mid sump will sit right on top of your cross member and the rear sump will really be cutting it fine with your steering rack (all guesses of course).
I'm going to assume you will want to keep your gearbox in the same place, so you need to measure the distance from the front of the bellhousing to the the back of the rack, and also to the front of the cross member. Then measure the distance from the back of the 1UZ (where the bellhousing bolts up) to the fore and aft extremities of the different oil pans. I don't mean to sound nasty, but I think you are anguishing over nothing! Smile
The front sump sits a long way forwards, and actually has a section that projects forwards under the crank pulley (bit like an Altezza 3SGE). Ultimately, you need to get out there with a tape measure and go nuts. Also if you have a digital camera handy, take a gazillion happy snaps.
Cressida Supra
Re: 1uz sump pics Tue, 23 September 2003 04:43 Go to previous messageGo to next message
gianttomato wrote on Tue, 23 September 2003 08:15
yes, yes and most likely yes
yes, i do want to keep the gbox in the same as i want to go manual 1uz, and having it 4" further forward could create problems. however, norbie/ed have given me a possible solution to this (i think an r154 or v160 would also cure this, but $$$)
if i was gonna leave the 1uz auto, then none of this would be a problem Sad
i didnt know that the front sump actually extended further out, thanks for that bit of info. maybe modding this sump would been the best.
i have been meaning to get under the car and do some measurements, but with my trolley jack out of order for the mo, it has made it a hard thing to do
i will try and do it this weekend tho
cheers GT
Peewee
Re: 1uz sump pics Tue, 23 September 2003 05:54 Go to previous messageGo to next message
Ah, didn't realise you were going manual. Adds an extra degree of difficulty.
Have you spoken to Jamie or HKSPete? Both these guys have manualized their 1UZs....maybe they'll be kind enough to get under their cars and measure things up for you. Be sure to ask which shifter position they are running.
Cressida Supra
Re: 1uz sump pics Tue, 23 September 2003 06:51 Go to previous messageGo to next message
hehehe, yeah, it kinda does throw a spanner in the works.
nah i havent spoken to em yet, but i'm pretty sure that neither of them had front mounts sumps to begin with, so this wouldnt have been a problem for them
plus, i'm currently using the second most rear shifter position, so getting are more rearward one seems unlikey, and would only make up .5" at max
i'll work something out, even if i go auto for a while, and go manual later when i have more money, and get a custom sump built
Cressida Supra
Re: 1uz sump pics Wed, 24 September 2003 05:05 Go to previous messageGo to next message
it looks easy to mod a front sump accoording to this, this and this
http://geocities.com/deonsv8hilux/page7.html
http://geocities.com/deonsv8hilux/page9.html
http://geocities.com/deonsv8hilux/page10.html
SupraPete
Re: 1uz sump pics Wed, 24 September 2003 07:21 Go to previous messageGo to next message
The lower part of the sump can be taken off the main part of the sump, and then modified easily. Main part - part that goes from sump to block, and runs all the way down the block to catch oil and funnel into lower sump. Lower sump - bubble bit that the oil actually sits in and the oil gets picked up from.
I started with a mid sump (crown) and went rear with the rear sump and pickup I simply swapped them over. Only problem was the dipstick which I'm still having problems with.
And I'm running a R154 box with a belhousing made from dellows that was 5mm too short.
Get the bellhousing from CRS.
Cressida Supra
Re: 1uz sump pics Wed, 24 September 2003 07:43 Go to previous messageGo to next message
hahah, damn
i plan to
Re: 1uz sump pics Wed, 24 September 2003 08:07 Go to previous messageGo to next message
HKSPete wrote on Wed, 24 September 2003 17:21
I also had this problem. In the end I tapped a hole into the aluminium corset and Loctited a fitting in place and press fitted a length of aluminium tubing as the dipstick. I also had to lightly trim the baffle plate for the dipstick. It was easy to get the right length when the motor was out of the car.....not so sure how you'd easily do that with the engine in situ without getting machinings into the sump.
SupraPete
Re: 1uz sump pics Wed, 24 September 2003 23:51 Go to previous messageGo to next message
I still havn't got my oil pressure guage on it. If I had one or the other I'd feel OK, but with both out Confused
mycarhasposessedme
Central coast NSW
Re: 1uz sump pics Thu, 25 September 2003 10:36 Go to previous messageGo to next message
Hi
Anyone got a pic of a rear sump 1uz
I'm doing a twin turbo 1uzfe/r154 into HZ Onetonner and have a front sump LS400 but need a rear.Anyone wanna swap?
[Updated on: Sun, 28 September 2003 01:43]
Re: 1uz sump pics Mon, 12 January 2004 01:07 Go to previous message
Unfortunately GT, it doesnt, unless there are 2 front sump varieties. (Can you clarify this?)
The front sump I have drops straight down at the front of the motor, doesnt extend.
Previous Topic:IT'S ALIVE!!!!
Next Topic:Turbo Manifold
Current Time: Sun Nov 1 12:17:39 UTC 2026
Total time taken to generate the page: 0.0068719387054443 seconds
