Toymods » Tech & Conversions » 85 Cressida W alignment specs wanted
85 MX73
Gippsland
85 Cressida W alignment specs wanted Mon, 22 September 2003 05:17 Go to next message
Can anyone help?
Im chasing the front end alignment specs for a 85 MX73 cressida Sedan.
Thanks in advance
Cressida Supra
Re: 85 Cressida W alignment specs wanted Mon, 22 September 2003 13:47 Go to previous messageGo to next message
firstly why?
secondly, what type of specs u looking for? original toe? camber?
85 MX73
Gippsland
Re: 85 Cressida W alignment specs wanted Tue, 23 September 2003 02:47 Go to previous messageGo to next message
Im looking for Toe, Camber and caster etc.
I have only just put the car on the road. And do not have a manual. The Tie rod/rack ends were replaced, and it had a bent strut. I have replaced them now and would like to set up the front end.
I have my own bubble type camber caster gauge.
I currently have
1 deg + camber
4 deg + Caster
3mm toe in
It seems to andle OK but would like to compare it with the manufactures specs. I have not found the specs on the net. I am running the original 15" mags.
Hope this helps.
thanks again. Can you confirm these settings.
Cressida Supra
Re: 85 Cressida W alignment specs wanted Tue, 23 September 2003 04:32 Go to previous messageGo to next message
i had my alignment done a few years back, after i put some kings srpings lowering springs in the front
i'll dig up the receipt and see what i can find for ya
from memory, i think 3 deg caster was more likely, but i'll check tonite
wilbo666
Re: 85 Cressida W alignment specs wanted Tue, 23 September 2003 05:23 Go to previous messageGo to next message
Whats the go with running +ve camber?
I thought it was a bad thing?
Cressida Supra
Re: 85 Cressida W alignment specs wanted Tue, 23 September 2003 14:07 Go to previous message
okay
according to the receipt
front axle (left,right)
caster = +3 deg,+3 deg
KPI = +10 deg,+11 deg
Camber = -47",-37" (60" in a deg)
Toe = 0 deg, 0 deg
hope this helps
[Updated on: Tue, 23 September 2003 14:08]
Previous Topic:Insurance
Next Topic:glove box lock
Current Time: Fri Nov 20 04:55:49 UTC 2026
Total time taken to generate the page: 0.0049481391906738 seconds
