Toymods » Tech & Conversions » 1G starter?
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon5.gif  1G starter? Tue, 23 September 2003 23:42 Go to next message
Are 1G starters non-standard?
I think mine is dying. It normally just clicks without rolling over, but yesterday, it didn't click at all when I turned the key... Did this all day long. Had to push start my car each time I needed to use the car. Disgusted
Just wanna avoid any nasty surprises if I pull the starter out and go to Repco or somewhere...
Re: 1G starter? Wed, 24 September 2003 13:25 Go to previous messageGo to next message
don't know how much it'll help, but part number is:
Toyota
28100-15040
[ND 028000-6362]
[12V 6G26]
(those last 4 digits were stamped onto the ID plate)
and why do i know all these numbers? because helmann's 1G (except block) is spread over about a dozen boxes in my spare room Wink
BTW: maybe the solenoid is snaffu but motor still OK?
Charles
Nark
Cabramatta, NSW
Re: 1G starter? Wed, 24 September 2003 23:45 Go to previous messageGo to next message
Kewlies. Thanks for that!
Nark
Cabramatta, NSW
Re: 1G starter? Sun, 28 September 2003 10:59 Go to previous messageGo to next message
Jacked the car up today and cleaned sprayed degreaser into the plug and guess what! It worked!
Lucky I tested it! Smile
Dylo
Re: 1G starter? Tue, 30 September 2003 00:56 Go to previous messageGo to next message
Nark,
I have heard there is a common problem with 1G's and their starters. They seem to have problems triggering the starter motor,the fix is to hook up a relay so the trigger wire triggers the relay open and then it feeds a straight 12v from a direct source.
Any more problems and u may wanna try this.
Nark
Cabramatta, NSW
Re: 1G starter? Tue, 30 September 2003 01:07 Go to previous message
You mean hook the trigger up so that it's coming straight from a 12V source?
Previous Topic:AE86 4AGE Bluetop Conversion Help
Next Topic:haltech f10 - 3tgte wireing diagram ?
Current Time: Sat Oct 31 13:34:39 UTC 2026
Total time taken to generate the page: 0.023946046829224 seconds
