Toymods » Tech & Conversions » Alternator - 4age
ae95
Alternator - 4age Wed, 24 September 2003 11:21 Go to next message
I recently got my alternator rebuilt (some sort of bosch one) by a mate and he said that it only produces 45 amps. is this too low for my 4age? if so what alternator could i use? ie from which car?
wilbo666
Re: Alternator - 4age Wed, 24 September 2003 11:42 Go to previous messageGo to next message
45amps is prbly fine, unless you have something that requires major power (subs etc), I think the 5M-E alternator is only a 45amps unit as well.
If its working fine I wouldn't loose sleep over it!
ae95
Re: Alternator - 4age Wed, 24 September 2003 12:51 Go to previous messageGo to next message
Ah ok. well my engine has a slight misfire. and the alternator was stuffed, so i assumed it was the alternator causing the misfiring. but now i have installed the rebuilt alternator and its still misfiring a little.What else can cause misfire? i have changed plugs and done alternator.
wilbo666
Re: Alternator - 4age Wed, 24 September 2003 14:15 Go to previous messageGo to next message
Hmm I'm not really much of a guru on misfires (check with someone else before you believe what I say! Rolling Eyes).
It might be your coil (not sure how you test this!)? Or maybe a spark plug lead? Sorry I can't help you more man but I'd rather let someone who has more of an idea steer ya in the right direction than give you shit info.
ae95
Re: Alternator - 4age Wed, 24 September 2003 16:41 Go to previous messageGo to next message
no worries dude!
thanks for the help
Re: Alternator - 4age Wed, 24 September 2003 17:05 Go to previous message
yep, I'd be checking all dizzy conncetions, coul pack connections, etc etc. that said, a friend is having a misfiring problem, and I'm buggered if I know waht's causing it Smile
Previous Topic:Drum to Disk Conversion - DOne
Next Topic:where is the jza80 air intake temp sensor?
Current Time: Thu Oct 29 14:48:18 UTC 2026
Total time taken to generate the page: 0.029697895050049 seconds
