Toymods » Tech & Conversions » Noise when entering a Corner...
ZZT231
melbourne.vic.au
icon4.gif  Noise when entering a Corner... Thu, 25 September 2003 06:47 Go to next message
Hey All,
When I take a hard right corner in my Supra it makes a grinding noise yet when i take a hard left corner, it doesn't make any noise at all?
Does anyone know what the sound is comming from?
After I got the wheel alignment done, it still makes the noise Mad and the tie rods seem ok.
Cheers.
DiZ_
The Eastwood MASSIVE !
Re: Noise when entering a Corner... Thu, 25 September 2003 07:40 Go to previous messageGo to next message
Wheel grinding the wheel arches maybe?
boudan
Re: Noise when entering a Corner... Thu, 25 September 2003 08:36 Go to previous messageGo to next message
possibly a valve in ur shock is either leaking or bitten dust...
this would cause extended travel maybe ?
Re: Noise when entering a Corner... Thu, 25 September 2003 09:03 Go to previous messageGo to next message
i'll put my mney on the super-obvious "wheel bearing" Very Happy
had similar symptoms when bearings have gone.
jack up the wheel/s and rotate the wheel by hand, any rumbling or noise indicates bearing dying.
ZZT231
melbourne.vic.au
Re: Noise when entering a Corner... Thu, 25 September 2003 10:58 Go to previous messageGo to next message
Thanks for the advice... I'll check it out tomorrow when i finish Uni...
Cheers.
ZZT231
melbourne.vic.au
Re: Noise when entering a Corner... Sat, 27 September 2003 02:31 Go to previous messageGo to next message
I put my car up and found out that it is not the wheel bearing... So that is not it...
hotrolla
Re: Noise when entering a Corner... Sat, 27 September 2003 08:50 Go to previous messageGo to next message
Have you checked the cv's
ZZT231
melbourne.vic.au
Re: Noise when entering a Corner... Sat, 27 September 2003 09:08 Go to previous messageGo to next message
hotrolla wrote on Sat, 27 September 2003 18:50
When I lifted my Supra up and checked the wheel bearing. I did not see any CV's in the front Laughing since it is RWD.
Cheers anyway Very Happy
Fattony
Re: Noise when entering a Corner... Sat, 27 September 2003 09:25 Go to previous messageGo to next message
I know this might sound a little silly, but i once in my foolish days owned a gti proton with a modded exhaust. I found i had the same noise, turns out it was the zorst hitting the side apron on the back of the car.
hotrolla
Re: Noise when entering a Corner... Sat, 27 September 2003 10:43 Go to previous messageGo to next message
It can still affect the CV's when turning though.
Just trying to help Sad
Classique71
Colac, Victoria
Re: Noise when entering a Corner... Sat, 27 September 2003 11:39 Go to previous messageGo to next message
could it be ........ a mudflap ?
my money was on the bearing too - or it could just be tyre noise - more load or something ..
strober
Re: Noise when entering a Corner... Sat, 27 September 2003 14:51 Go to previous messageGo to next message
loose misc. items in the boot maybee? Confused
Re: Noise when entering a Corner... Sun, 28 September 2003 06:21 Go to previous messageGo to next message
you haven't said if it is from the front or rear yet either?? which one??? (and is the noise actually coming from the left or right??)
is it a grinding/scraping noise, or grinding/rumbling noise? high pitched, low pitched??
check your tyres and inside the guards for any recent scrape marks, check that your hubs are not loose (if they are, the brake disc can move a little and scrape on the brake pads/caliper)
if everything seems tight, and there are no scrape marks, then keep looking, for something to scrape, it must have contact, and you should be able to see evidence of that....
yup, exhaust is a good point too, could be touching anywhere under the body..
also check engine mounts, and suspension mounts to see if anything is moving aroudn too much.
should be able to find the noise with a methodical approach Smile
[Updated on: Sun, 28 September 2003 06:28]
ZZT231
melbourne.vic.au
Re: Noise when entering a Corner... Sun, 28 September 2003 14:48 Go to previous messageGo to next message
Embarassed Sorry Oldcorollas Embarassed
Forgot to mention where the noise is originating from... It's the front, but only when i put a fair bit of weight on the left wheel taking a hard right corner... But doesn't do it when i take the corner in the opposite direction
I'll lift the car up again tomorrow and remove the wheel and check the bearings, hub, rotors, brakes etc to see what it could be...
Good old Uni holidays always turn out to be "working" holidays Laughing
Keep you all informed.
Cheers.
Fattony
Re: Noise when entering a Corner... Tue, 30 September 2003 08:01 Go to previous messageGo to next message
Ok from the front, cant be exhaust grinding, how about your wheel alignment, doesnt sound like a tyre rubbing on the guard does it.
79rollaboy
NSW Engadine
Re: Noise when entering a Corner... Tue, 30 September 2003 10:00 Go to previous messageGo to next message
its would be on the left side because the inside suspension doesnt really move much where as the left side does the moving,
Re: Noise when entering a Corner... Tue, 30 September 2003 10:01 Go to previous messageGo to next message
loose engine mount?
MR PLOW
neverland
Re: Noise when entering a Corner... Wed, 01 October 2003 11:20 Go to previous messageGo to next message
have you got non standard wheels on it ie wider.
- wouldn't be wheel bearing as it would do it all the time.
- i'm going either the whell/tyre is rubbing on the inner guard or something along those lines.
- it may even be the spring rubbing on the shock (metal on metal)happened to me.
- try even spraying WD40 or something like that on the rubbers one at a time take it for a drive and see if its still there untill its not anymore then bingo.
-dont start spending money trying to fix things other wise it will leave you poor.
thats me with years of knowledge.
brad
(oh and if your a customer "don't ask me i just work here")
ZZT231
melbourne.vic.au
Re: Noise when entering a Corner... Wed, 01 October 2003 16:10 Go to previous messageGo to next message
Thanks for the reply all Very Happy
Haven't had enough time to look at the car and it is not causing me too much grief... It could be any number of the things in the car that could cause the sounds. As long as I don't go too fast into a right corner (placing a lot of weight on the left wheel), everything seems fine Confused
I'll have a look to see if any of the wheel arch flares, suspension or anything located there could cause the problem...
Cheers.
The MA61 is completely stock.
Re: Noise when entering a Corner... Wed, 01 October 2003 16:47 Go to previous message
is it metal-on-metal grinding, or tire-on-plastic "scrubbing" ? check your tires for wear anyhow, inside and out, as that could be waht's causing it.
GO TO BED!
Previous Topic:Microtech LTX8 for 3T GTE?
Next Topic:ae86 wiring
Current Time: Mon Oct 26 06:00:53 UTC 2026
Total time taken to generate the page: 0.087440967559814 seconds
