Toymods » Tech & Conversions » Best Material for airbox construction?
BlackSupra
Best Material for airbox construction? Thu, 25 September 2003 11:27 Go to next message
What is the best material to use int he construction of an airbox in relation to heat transfer/absorbtion properties.
Im going to guess carbon fibre, but anything else that people can inform me of is cool.
Prices too for materials would be nice.
Ta, guys.
RobST162
Re: Best Material for airbox construction? Thu, 25 September 2003 11:30 Go to previous messageGo to next message
I was going to, uh, am going to use fiberglass for mine. FMS in Sydney, and elsewhere I belive sell it at a price about 100 times better than your hardware store.
STR8 2.8
Re: Best Material for airbox construction? Thu, 25 September 2003 11:37 Go to previous messageGo to next message
sell the fibreglass....
what glass are u talkin about?
like prefab or something?
BlackSupra
Re: Best Material for airbox construction? Thu, 25 September 2003 12:06 Go to previous messageGo to next message
Now insulation bats in homes are essentially fibre glass are they not?
STR8 2.8
Re: Best Material for airbox construction? Thu, 25 September 2003 12:44 Go to previous messageGo to next message
true
STR8 2.8
Re: Best Material for airbox construction? Thu, 25 September 2003 12:45 Go to previous messageGo to next message
hmm a layer of polished aluminium around a fibreglass box with fibreglass insulation in between. ha
show us your charge temps there
BlackSupra
Re: Best Material for airbox construction? Thu, 25 September 2003 12:47 Go to previous messageGo to next message
But the metal will absorb unwanted heat
STR8 2.8
Re: Best Material for airbox construction? Thu, 25 September 2003 12:48 Go to previous messageGo to next message
but it will reflect some of it, and the insulation will keep the inners cool
BlackSupra
Re: Best Material for airbox construction? Thu, 25 September 2003 12:54 Go to previous messageGo to next message
Or why not have 100% reflection Very Happy
STR8 2.8
yeh, build a box out of mirrors.
BlackSupra
Re: Best Material for airbox construction? Thu, 25 September 2003 13:00 Go to previous messageGo to next message
Don't make me slap you
STR8 2.8
Re: Best Material for airbox construction? Thu, 25 September 2003 13:01 Go to previous messageGo to next message
but it wud be da sickest at auto salon
cambelt
melb
Re: Best Material for airbox construction? Thu, 25 September 2003 15:01 Go to previous messageGo to next message
VN commodore air box is great for conversions , v8 one even has a right angle out pipe fitting
BlackSupra
Re: Best Material for airbox construction? Thu, 25 September 2003 21:31 Go to previous messageGo to next message
Already have a pod filter setup, and i did think about that airbox aong witht he AU falcon one.
Corvid
Re: Best Material for airbox construction? Thu, 25 September 2003 21:46 Go to previous messageGo to next message
if you want true uber insulation Smile buy yourself some of that stuff they use for offsite big fridges its two bits of alloy sandwiched with insulation.. you could make it look good if you wanted too.. hell you could cool your beers in it Smile
BlackSupra
Re: Best Material for airbox construction? Thu, 25 September 2003 22:31 Go to previous messageGo to next message
hehe where does one find this stuff and is it any different to what STR8 2.8 suggested?
I want to do the intake once and get it right, ceramic coated stainless piping, removing resonators, boxed pod filter, cold air intake.
Very Happy
Re: Best Material for airbox construction? Thu, 25 September 2003 23:00 Go to previous messageGo to next message
well...
a polished metal finish will reflect some direct radiated heat, but it still absorbs quite a lot, and will absorb heat by conduction from the hot air too.
what you need is to minimise the:
heat absorption onto the outer side,
heat transfer to the inner side,
heat transfer to the incoming air.
i would say the best would be to use a core of very insulating material, expanded polysteyrene comes to mind, but that is flammable and not petrol vapour resistant... maybe expanded polyurethane (i think that is what is used in industrial fridges??) like the "space filler" cans you can get.... but i'm sure you can get sheets from somewheres, mayeb try clark rubber? they might know.
anyways, and then use either fibreglass or carbon fibre for the inner and outer surfaces.. bonus is you can shape the foam and lay the glass on top. laying on the inside might be interesting, but you could do it in two halves and then epoxy together.
heat transfer coefficient of f/glass or c/fibre is much lower than any metal.
next is to get a fridge compressor and... Razz
BlackSupra
Re: Best Material for airbox construction? Thu, 25 September 2003 23:02 Go to previous message
...chill beers Cool
Previous Topic:4AGE throttle body questions
Next Topic:EFI Upgrade on 4AGE
Current Time: Thu Nov 19 21:56:09 UTC 2026
Total time taken to generate the page: 0.0059571266174316 seconds
