Toymods » Tech & Conversions » 18RG INTO ta22
Jason
18RG INTO ta22 Fri, 26 September 2003 01:00 Go to next message
Hi all
I know a guy who is putting a 18rg into a 22 and he is running into some difficuility with the cross member and rear engine mounts on the box i know there are people out there who have done this conversion and i was just wondering if i could pick your brains for some clues.
Thanks in Advance
Jas
dorikin
NE Melbourne
Re: 18RG INTO ta22 Fri, 26 September 2003 05:49 Go to previous messageGo to next message
the mounts will have to be custom made as far as i know, unless he uses a RA2X crossmember (???)
i have to ask though, why bother with an 18R in a TA22. wouldn't a 2T/3TG hybrid be a better, smaller and lighter option???
well, best of luck with the conversion.
Jason
Re: 18RG INTO ta22 Fri, 26 September 2003 05:58 Go to previous messageGo to next message
Its a 18rg not a 18r and the problem is that he has already gone ahead and done most of the work so this is like shutting the gate after the horse has already bolted
[Updated on: Fri, 26 September 2003 05:58]
dorikin
NE Melbourne
Re: 18RG INTO ta22 Fri, 26 September 2003 07:43 Go to previous messageGo to next message
18R or 18RG, either way it's the same block, and the same difficulties associated with bolting it into the TA22. hopefully someone else here knows about the compatibility of a RA2x crossmember into a TA22. people use TA23 crossmembers into RA23's when they throw away the boat anchors and use T-series engines, but i dont think that the RA2x crossmembers will go into the TA22 easily.
otherwise it's custom all the way...
[Updated on: Fri, 26 September 2003 07:44]
ChuckLandwehr
Re: 18RG INTO ta22 Sun, 28 September 2003 06:19 Go to previous message
Use your standard 22 X member, (23/28 won't fit) use a corona sump and oil pick up, them custom fab some engine mount brackets, and gearbox x member to body mounts.
regards Chuck.
Previous Topic:ke 70 diff?
Next Topic:Toyota color code
Current Time: Tue Oct 27 08:07:12 UTC 2026
Total time taken to generate the page: 0.035662889480591 seconds
