Toymods » Tech & Conversions » 4agze idle adjust?
TecEVO
Switzerland
icon5.gif  4agze idle adjust? Fri, 26 September 2003 03:18 Go to next message
Simple question how do you change the idle speed.
There is a screw that limits the return movement of the throttle cable wheel but I have not tried turning it as when i move the wheel just a little, like turning the screw would, the computer starts hunting the engine. Ie it revs up 500 rpm for 2 seconds then drops back for 3 secs then speeds up again.
Maybe I'm moving the wheel further than the screw would?
But I also noticed a little rubber plug then when remove reveals a screw then looks like it might be an idle bypass adjustment?
Just thought I'm might ask before I go do it.
EVOSTi
cambo
      no
Re: 4agze idle adjust? Fri, 26 September 2003 06:34 Go to previous messageGo to next message
if your unsure, just mark it with liquid paper then try it, if you muck it up just turn it back. but i gotta ask, if your idle is now good, could this be due to another problem?
feral4mr2
Bundaberg, Qld.
Re: 4agze idle adjust? Fri, 26 September 2003 09:04 Go to previous messageGo to next message
Freak the srew thats under the rubber plug on the throttle body is your idle adjustment.
TecEVO
Switzerland
Re: 4agze idle adjust? Wed, 01 October 2003 04:15 Go to previous messageGo to next message
Thanks I will give a go.
sprinterboy4agze
Re: 4agze idle adjust? Wed, 01 October 2003 05:12 Go to previous messageGo to next message
mine does that hunting as well, i got a after market computer on it i tuned it but still the same i tried that idle adjusting it helped only abit because it used to cut off but since turning the knob it doesnt cut off unless its really cold or ive just started my car so i have to keep the revs on 2 and wait for 5 minutes till its warmed up
i tried differ intercooler that didnt help
when its warmed up it doesnt hunt as much the other thing is i dont have a thermostat so im guessing its that
or some air leak somewhere but just cant find it
why do u want to fiddle with the idle controller? what is your rev on
feral4mr2
Bundaberg, Qld.
Re: 4agze idle adjust? Thu, 02 October 2003 08:24 Go to previous message
Freak not really a good idea to run with-out a thermastat man.
a couple gze's i have seen with a mirotech used a old school choke idea by opening the thottle butterfly a little via the butterfly stop screw.
so it idles at a reasonable rev when cold.
Previous Topic:Does your 4AGZE CAS melt??
Next Topic:RA60 CELICA
Current Time: Sat Oct 24 09:42:31 UTC 2026
Total time taken to generate the page: 0.016817092895508 seconds
