Toymods » Tech & Conversions » MA61 bastard don't start
Hirogen
Melbourne, Australia
      WTF is a jabber?
MA61 bastard don't start Sat, 27 September 2003 07:23 Go to next message
Ok some genius put 2 stroke into the MA61, which has obviously crapped it up something shocking. We have put injector cleaner through it and its stopped smelling like 2 stroke every time we crank it over. Only problem now is, it wont fire. We tried using "start ya bitch" but still nothing. Anybody got any ideas on what we could try to get the friggen thing going?
Re: MA61 bastard don't start Sat, 27 September 2003 07:43 Go to previous messageGo to next message
the oil/2-S shit may have fowled/stuffed the plugs.
can you pull 'em out and give the ma good soak in 4-S petrol (to remove any oil/shit then leave them dry in direct sun or hot air (tho i would advise NOT using any electrical heating device to provide hot air in case you light-up some fuel).
and you getting a spark at all?
Charles.
Hirogen
      WTF is a jabber?
Re: MA61 bastard don't start Sat, 27 September 2003 08:05 Go to previous messageGo to next message
yeah it did foul the plugs, quite a few times, have pulled them out a few times, and cleaned them. We even got some of those bosch 4 prong ones, and even still, no go, it seems to be almost starting then just wont.
Jason
Re: MA61 bastard don't start Sat, 27 September 2003 08:17 Go to previous messageGo to next message
Bit of a dumb question but have you got rid of all the 2 stroke fuel from the system because this wont help at all Smile
Hirogen
      WTF is a jabber?
Re: MA61 bastard don't start Sat, 27 September 2003 08:21 Go to previous messageGo to next message
yeah we drained it all, and have been trying to run it on BP ultimate in an attempt to clean it out a bit, still no luck.
must be not fueling the engine properly - specially as you're replaced the plugs Wink
have you tried beating-up/hurting the idiot who put mower fuel in it? Cool
e.g. "if you don't start this time, i'll have to begin punching him! "
can you check if you're getting fuel at the rail? do the plugs smell like raw fuel if removed? maybe the injectors are clogged with oily shit from the 2-s? do you have enough fuel pressure (maybe the pressure regulator didn't like the oil)?
was the timing changed/modified while attempting to rid engine of 2-S? any backfire or exhaust pops while trying to start (enough fuel, timing way wrong)
Charles.
Hirogen
      WTF is a jabber?
Re: MA61 bastard don't start Sat, 27 September 2003 08:56 Go to previous messageGo to next message
1. Yeah fuel is at the rail
2. Yep, the plugs smell like raw fuel when we take em out
3. Used some injector cleaner to try to get rid of the shit
4. Not sure of the pressure, any way to check?
5. Timing hasnt been altered, and the chain hasnt been touched
6. Thanks for the help here guys, really appreciate it
Re: MA61 bastard don't start Sat, 27 September 2003 09:41 Go to previous message
Hirogen wrote on Sat, 27 September 2003 18:56
gauge in place of fuel line to cold start injector is handy spot - but seeing as the injectors can soak the plugs, i'd say it has enough pressure.
i suppose you have to go back to basics:
plug leads in right order?
rotor in dizzi?
is coil sending a spark? (hook up HT lead from coil directly to a handy s/plug, earth it to the engine, crank and watch for spark - or get 2-S culprit to hold plug and listen to them yell?)
put timing lite on plug lead one and see if sparking at right time for low rpm while cranking?
are there any errors from ECU? (use engine check light?)
dunno ... am all out if ideas...
otherwise, slam hood shut, go into kitchen and get very drunk, by late sunday afternoon problem may have gone away while you were dealing with your hangover? Razz
Charles
Previous Topic:What to do about crappy paint!
Next Topic:Supercharging 18rc
Current Time: Sun Nov 22 06:23:15 UTC 2026
Total time taken to generate the page: 0.014011144638062 seconds
