Toymods » Tech & Conversions » too heavy, too low
truenolevin
too heavy, too low Sat, 27 September 2003 15:24 Go to next message
i just changed my rims to ssr mesh but since changing my rims from modern looking ones, the side guards and the inners has been grinding against the wheels when theres a pot hole, break too hard or change direction at high speeds. the current engine is a 3tgte.. seems that its due to the weight of the engine. Any idea what i should do ?
AE82TwinCam
Canberra, ACT
Re: too heavy, too low Sat, 27 September 2003 17:12 Go to previous messageGo to next message
ummm you changed your rims and now they grind... and you think the engine is the problem?? I don't really see the connection here...
There's a few options I guess you could look at.. Get your guards rolled a bit, maybe it will be enough to stop the scraping. You could also maybe get some lower profile rubber on the rims to give a little bit of extra space between the top curve of the tyre and the guard.
Doing an engine conversion to a lighter engine variant seems to be a really expensive way to seeing if the guards rub against the tyre.
Just my thoughts...
-Andrew
ae95
Re: too heavy, too low Sat, 27 September 2003 20:15 Go to previous messageGo to next message
wrong offset?
rims too wide?
EVOSTi
cambo
      no
Re: too heavy, too low Sun, 28 September 2003 11:16 Go to previous message
could be the wrong offset. my tyres scrub the inner guards when i corner hard and that was just after i did my brake upgrade which slightly increased track which has the same effect as changing offset i spose.
Previous Topic:What mods Can Be Done To A 3T/C??
Next Topic:costs of going 18RGEU TURBO
Current Time: Sun Oct 25 12:45:39 UTC 2026
Total time taken to generate the page: 0.03076696395874 seconds
