Toymods » Tech & Conversions » 7mgte -3sgte, same injectors ?
mycarhasposessedme
Central coast NSW
7mgte -3sgte, same injectors ? Sun, 28 September 2003 02:08 Go to next message
Anyone know if 7mgte and 3sgte have the same injectors.
I have heard that 3sgte injectors come in side feed and top feed, the top feed being the same as 7mgte (430cc)is this right and do they have the same electrical connection?
Thanks.
spectral
Re: 7mgte -3sgte, same injectors ? Sun, 28 September 2003 22:48 Go to previous messageGo to next message
I believe they do share the same 430cc side-feed (not top) injectors.
The later model Gen3 3S-GTE uses 540cc injectors I believe.
[Updated on: Sun, 28 September 2003 22:53]
7mgtema71
Re: 7mgte -3sgte, same injectors ? Mon, 29 September 2003 05:15 Go to previous messageGo to next message
No, the 7mgte injectors are rated by toyota at 440cc, but i flow tested mine and they messured 486cc on average. I don't know about the 3sgte ones, but i know one particluar model gt4 3sgte motor had 800cc injectors.
Oh, and the 7m injectors are top fed too.
Allan
Re: 7mgte -3sgte, same injectors ? Tue, 30 September 2003 01:54 Go to previous messageGo to next message
but are thay peek and hold style like the 7m-gte is the next question!
Allan
JustenGT4
Re: 7mgte -3sgte, same injectors ? Tue, 30 September 2003 03:21 Go to previous messageGo to next message
Lots of confusion here.
Gen I 3SGTE injectors are 430cc/min and top feed same as the 7MGTE injectors. I can never recall whether they are high or low impedance but physically they should be a straight swap.
Gen II 3SGTE injectors are also 430cc/min but side feed
Gen III 3SGTE are 540cc/min and also side feed.
There were NEVER any factory 800cc/min 3SGTE injectors. TTE do 920cc/min but just a tad large for most street cars Smile
As for the flow rating. You have to have tested your injectors at the same pressure and same duty cycle to have any meaningful comparison. I believe the Toyo injectors are rated at 38psi at 100% duty but i'm happy to be corrected.
FLY PSI
Re: 7mgte -3sgte, same injectors ? Tue, 30 September 2003 09:27 Go to previous message
I have 7MGTE injectors in my 3TGTE and i also have 2 3SGTE.
Both the 7M and 3S injectors are the same size, top feed,plug
and color. I will be getting them all cleaned and flow checked soon so i can give the results then.
Previous Topic:CAI on ae86
Next Topic:20V LSD Gearboxes??
Current Time: Sun Nov 1 22:46:13 UTC 2026
Total time taken to generate the page: 0.0045831203460693 seconds
