Toymods » Tech & Conversions » rear end loose
neat 20valve
icon9.gif  rear end loose Sun, 28 September 2003 21:16 Go to next message
hi all i got my new sx seca and the rear end is so loose its a joke to drive.
if i go into a corner with a bit of speed (not much) the whole rear end will snap and kick like someone is slaming into the side of u, i think it could be the rear strut brace bushes, anyone got any other answers?
regards Craig.
bass_boy
Re: rear end loose Sun, 28 September 2003 22:49 Go to previous messageGo to next message
id like to hear this too, as my new sx hatch has the same prob.. not quite a severs, but when u go over small bumps in the road u can hear a few rattles from the rear... i have checked and its all tight, guess i am gonna take into the shop?..
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: rear end loose Sun, 28 September 2003 23:06 Go to previous messageGo to next message
Do you guys have big rear sway bars? Rollas have very light rear ends and a big rear swaybar will make it more pronounced.
If not, then check that your shocks aren't worn out.
neat 20valve
Re: rear end loose Sun, 28 September 2003 23:37 Go to previous messageGo to next message
my shocks and sway bars are all stock, the stock tyres that where on it where totaly worn out on the inner side (down to the wire) so it is a sway prob im thinking. i want to fix this week.
Nark
Cabramatta, NSW
Re: rear end loose Sun, 28 September 2003 23:48 Go to previous messageGo to next message
It's not IRS is it?
It shouldn't wear the tyres on the inside!! Methinks something is loose.
neat 20valve
Re: rear end loose Mon, 29 September 2003 00:11 Go to previous messageGo to next message
Yeah it is independent rear suspention, i put my 15in wheels on it sat night and they are sitting ok, the rear wheels also have side movement. (hold with both hands and pull and push) not much but enough,
ehendrikd
ballarat
Re: rear end loose Mon, 29 September 2003 00:23 Go to previous messageGo to next message
soften (if possible) front body roll, strengthen rear body roll, wider tyres on the rear, shift weight to the front
[Updated on: Mon, 29 September 2003 00:28]
neat 20valve
Re: rear end loose Mon, 29 September 2003 00:28 Go to previous messageGo to next message
Hay man i think u missed the point, look back up the top.
Its just as if i have flat tyres and they are rolling off the rims. then straightens up and does it all over again.
im lost with it. will have a good hard look this arvo
any more answers more than welcome.
regards Craig.
ehendrikd
ballarat
Re: rear end loose Mon, 29 September 2003 00:31 Go to previous messageGo to next message
ahhhh 'loose' as in 'nut is loose', not 'oversteer'
sorry Razz
neat 20valve
Re: rear end loose Mon, 29 September 2003 01:02 Go to previous messageGo to next message
im booked in for a 28 point suspention check this arvo,
so i will let u all know what comes out of it.
later Craig.
neat 20valve
Re: rear end loose Mon, 29 September 2003 21:11 Go to previous messageGo to next message
i got a 28 point suspension check yesterday,
the rear end is all over the place because:
both rear shocks are leaking,
all 4 lower bushes are worn,
and the brace bushes also worn,
but the best bit is the left rear trailing arm is bent! Crying or Very Sad
also the front shock also leaking and all 4 lower bushes also gone.
they said it would be $1300 to fix so im getting the parts from the same place as i did the first time and putting them in my self. (last time they said $650 and it was done for $200)
well what can i say fu*k it.
regards Craig.
Nark
Cabramatta, NSW
Re: rear end loose Tue, 30 September 2003 00:37 Go to previous messageGo to next message
Geez!! Go get a second opinion before you fork out any money.
shinybluesteel
melbourne
Re: rear end loose Tue, 30 September 2003 00:42 Go to previous messageGo to next message
i agree with nark, i went to get a 28 point money check and wheel alignment on my car, he told me the back shocks were screwed, i told him that was funny, because i had just replaced them a month ago..
take it to a few places, but the bent control arm sound like the cause, replace that and see how you go. get someone to show you where it is bent too.
neat 20valve
Re: rear end loose Tue, 30 September 2003 03:04 Go to previous message
Yeah all good advice,
not sure about the shocks,
but i will replace all the bushes, i have done in my last one and it handled so much better,
and the control arm well what do i say, how on earth did he do it the car is low enough if is was a gutter it would have hit the side of the car as well? no idea.
i'll let u know what happens with it.
craig
Previous Topic:tramp rods/traction bars/slapper bars ect
Next Topic:AE86 4AGE Bluetop Conversion Help
Current Time: Sun Nov 1 23:36:50 UTC 2026
Total time taken to generate the page: 0.0069270133972168 seconds
