Toymods » Tech & Conversions » re: 3sgte/ct26 turbo
GTMR2
re: 3sgte/ct26 turbo Wed, 17 July 2002 09:08 Go to next message
Hi all
I have a 3sgte/ct26 turbo powered MR2. I want to rebuild the turbo for better performance. I have been quoted around $1300 to extract the most power from the standard ct26, this includes a full rebuild, hi flow and T04 wheel. Should I rebuild the standard ceramic ct26 or replace it with a new larger unit at well over $2000?
regards,
Richard
richard@satworld.com.au
TA22-3SGTE
MACKAY
re: 3sgte/ct26 turbo Wed, 17 July 2002 13:38 Go to previous messageGo to next message
The cheapest way is to get a CT26 off a 7MGTE as it has a larger exhaust housing but the same size rear wheel and comp wheel is 47mm compared to 40mm and has steel shaft .
Trevor
TURBO CALDINA
gold coast
re: 3sgte/ct26 turbo Sun, 21 July 2002 00:04 Go to previous messageGo to next message
if your going to rebuild it any way stick with the original turbo. when they high flow it they will put a steel wheel in it. i have a freind that had his high flowed from Dymanic turbos in bris with the largest t3 wheel they could fit and had a very good gain from that. 208hp at the wheels with only a jap plug and play computer and a very free flowing exaust and 15psi
jase
re: 3sgte/ct26 turbo Sun, 21 July 2002 13:24 Go to previous messageGo to next message
208 rwhp?! With 15psi and a computer?
Sounds great.
There isn't enough fuel is there?
Sure there's nothing else done? Injectors etc.
TURBO CALDINA
gold coast
re: 3sgte/ct26 turbo Mon, 22 July 2002 08:40 Go to previous messageGo to next message
its getting plenty of fuel
the same computer is still running the motor only now it has a garrett GT30R turbo and was dynoed on saturday to produce 240hp at the wheels on only 12psi and the air fuel ratio is still in around 11.5/1.
quarter mile time before the new mods was 13.4
[mikey]
re: 3sgte/ct26 turbo Mon, 22 July 2002 13:42 Go to previous messageGo to next message
with standard ct26a im making 204hp @ wheels on 1bar.....
which is close to 195kw@flywheel which is right.
Toyostar
re: 3sgte/ct26 turbo Tue, 23 July 2002 10:26 Go to previous messageGo to next message
So where's a good place to getr one of these babies Rebuilt...i just want the compressor wheel changed over and new seals etc...what would the rough guesstimate price be ya reckon?
Have a good one
Pete
[mikey]
re: 3sgte/ct26 turbo Tue, 23 July 2002 12:18 Go to previous messageGo to next message
try dynamic turbos in toowoomba, bloke ive spoken to with a cortina up there said they do a fantastic job with everything, and they do all his turbo work
jase
re: 3sgte/ct26 turbo Tue, 23 July 2002 23:19 Go to previous messageGo to next message
Richard, I'm in the process of getting a rebuilt ct26 sent from NZ. Purely because this guy has done alot of them, and I have kinda an easy way to get it from there.
If you want I can put you in contact with the guy there.
Mikey, thats great! I'm organising a new computer to go with the new turbo and have been fairly concerned about fueling. What sort of revs did you need for those figures?
Turbo Caldina, hope I didn't sound doubtful. What series of 3sgte is this?
TURBO CALDINA
gold coast
re: 3sgte/ct26 turbo Wed, 24 July 2002 06:37 Go to previous messageGo to next message
its a series 2 in a 92 mr
[mikey]
re: 3sgte/ct26 turbo Wed, 24 July 2002 08:44 Go to previous messageGo to next message
jase,
thats standard turbo so peak power was around 6200-6300rpm? havent worked it out exactly
not very much revs at all...
with a high flow ct26 t04e 50 trim front wheel, power will peak close to 7000rpm or more depending on cams and head flow..and they are good for around 380-400hp @ 2.3:1 pressure ratio....so 1.3bar boost or so..
michael.
TURBO CALDINA
gold coast
re: 3sgte/ct26 turbo Thu, 25 July 2002 08:23 Go to previous message
1.3 bar is a bit much for the bearings to handle
the turbo on the friends mr2 lasted about 12 months of hard driving (drifting)before a blade fell of the exaust wheel
and when rob at turbo dynamics pulled it apart to rebuild it they found that the bearing case was unrepairable
because the ct26 bushes are only 320 degrees they dont last as long at higher than 13psi and the only company i have found toreplace the bushes with a proper ball bearing is blitz but the cost of that turbo is around the $4000 mark
[Updated on: Thu, 25 July 2002 08:25]
Previous Topic:weight of 4AGE head?
Next Topic:exhaust manifold....
Current Time: Thu Nov 19 21:23:53 UTC 2026
Total time taken to generate the page: 0.0081439018249512 seconds
