Toymods » Tech & Conversions » Ma61 aletnator upgrade
boudan
Ma61 aletnator upgrade Mon, 29 September 2003 14:11 Go to next message
Can anyone suggest an aleternator upgrade, or where to find information about alternators etc?
BlackSupra
Re: Ma61 aletnator upgrade Tue, 30 September 2003 00:24 Go to previous messageGo to next message
Give you some ideas, but alasim guessing its 5ME POWA! Should still be doable though.
http://www.celicasupra.com/mk3altinstall.html
Alternatively, you could see if can remove and replace the brushes from inside the alternator itself (much cheaper!)
Re: Ma61 aletnator upgrade Tue, 30 September 2003 05:49 Go to previous messageGo to next message
who made your current one? you might be able to upgrade the guts to higher amperage.... particularly if it's a bosch.. but it's pretty easy to adapy any alternator to any motor. you just need to keep your current pulley and possibly make up new brackets.
boudan
Re: Ma61 aletnator upgrade Tue, 30 September 2003 06:03 Go to previous messageGo to next message
atm the stock toyota 84 supra ...
when you say "guts" are you referring to the same method of the above post "replacing the brushes"... ??
Re: Ma61 aletnator upgrade Tue, 30 September 2003 06:08 Go to previous messageGo to next message
hmm, a little more complicated than that..
for my KE70 alternator, which is a 40amp one, i took out both the stator and rotor, and also the field diode assemble and brushes, out of an XF falcon 60A alt, and oput it into mine.
basically, you swap the front and rear housing onto the internal parts of the bigger alt, and then you have a higher ampage alternator, but with your original mountings.
is usually easy to find a higher rated Bosch part that will slip in, but maybe not for mitsu or others
BlackSupra
Re: Ma61 aletnator upgrade Tue, 30 September 2003 07:12 Go to previous messageGo to next message
http://www.autoshop101.com/forms/h8.pdf
V8_MA61
Re: Ma61 aletnator upgrade Tue, 30 September 2003 07:16 Go to previous message
your best bet is to take it to a wreckers (jap only) and walk around trying to match it with other late model toyotas...they should share the same bolt pattern, and be very similar in mounting points. Just a thought..
Previous Topic:20V LSD Gearboxes??
Next Topic:tramp rods/traction bars/slapper bars ect
Current Time: Sun Nov 1 05:09:17 UTC 2026
Total time taken to generate the page: 0.016249895095825 seconds
