Toymods » Tech & Conversions » Microtech MTX-12 on 4agze, yes or no?
twincam_ke20
Castlemaine Vic
Microtech MTX-12 on 4agze, yes or no? Tue, 30 September 2003 10:03 Go to next message
Hi all, is an aftermarket comp (Microtech MTX-12) worth it on a gze if i keep the s/c? what other things would it alow me to adjust that the stock ecu wont?
or would it best suit if i ONLY go the turbo route?
tin can
Re: Microtech MTX-12 on 4agze, yes or no? Tue, 30 September 2003 10:09 Go to previous messageGo to next message
how u going mate my mate got a microtech on his 4agze and it idles realy weird but i dont know if its the microtech
good luck
jess
sideshow
Re: Microtech MTX-12 on 4agze, yes or no? Tue, 30 September 2003 11:01 Go to previous messageGo to next message
all u need is the mt8 microtech
use the original ignitor and coil setup
i have wired up afew
they do an ok job
only prob i find is the cold start is bit hard to perfect
best thing to do is fit an auxilary air valve which lets in more air when cold then closes off as engine warms up
nos4ag
Re: Microtech MTX-12 on 4agze, yes or no? Wed, 01 October 2003 10:24 Go to previous messageGo to next message
Yeah dude, you only need the MTX-8. I have one on my AE82 twin cam and I havent had a problem with it, and the cold start is perfect! I also had a idle problem, which happened to be a faulty T.P.S. The throttle was closed but the microtech was reading that the throttle was about 5% open. I put on a new T.P.S and BEAUTIFUL!!!! Smile You will be able to adjust air/fuel ratios, increase/decrease timing, rev limit, boost cut, and heaps more things! And dont forget, you will be able to do away with nearly all the anti-pollution crap on the motor aswell.
You never never know if you never never go!
Regards, NOS4AG!
nos4ag
Re: Microtech MTX-12 on 4agze, yes or no? Wed, 01 October 2003 10:26 Go to previous messageGo to next message
Oh and by the way, My 4AGE is turbo not supercharged. Smile
10sec_rx7
Syndey
Re: Microtech MTX-12 on 4agze, yes or no? Wed, 01 October 2003 22:49 Go to previous message
MTX12 is a over kill for a 4age, but it will work if you have one,
i have done heaps of them with LT8's using the stock coil/igniter setup, on a GTE i would use a LTX8 with coil packs,
alot of idle problems are due to people not setting the TPS correctly, what this does it makes the car use the load map not the idle map (in matrix mode this is less of a issue)
NOS4ag,
you didnt need to buy a new tps, you can adjust the settings in the TPSCAL screen,
cold start is a problem if you remove all the idle up stuff from the bottom of the throttle body, if you leave it there you will have no problems with the stock cold settings, also the newer LT's have a lot more cold tuning which makes it a lot easier to get it right,
BTW the MT series are no longer made, they have been replaced with the LT series which is about to be replaced by the LTs series
Dale
Previous Topic:1UZFE in ta22 celica
Next Topic:Microtech LTX8 for 3T GTE?
Current Time: Mon Oct 26 08:42:03 UTC 2026
Total time taken to generate the page: 0.0049920082092285 seconds
