Toymods » Tech & Conversions » GT4 owners ( fuel pump relay )
CrAiGzEE
south of the big smoke
GT4 owners ( fuel pump relay ) Wed, 01 October 2003 01:29 Go to next message
where abouts does this bolt too?
i didnt see where it orginally was mounted when we took the engine out, mate wreckons it fell out from underneath the car somewhere
Craig
a pic would be great,
Very Happy
JustenGT4
Re: GT4 owners ( fuel pump relay ) Wed, 01 October 2003 04:20 Go to previous messageGo to next message
It should bolt to the radiator on the drivers side of the engine bay from memory. Either there or a bracket near by there anyway
CrAiGzEE
Re: GT4 owners ( fuel pump relay ) Wed, 01 October 2003 04:31 Go to previous messageGo to next message
cheers mate
much appreicated
sideshow
Re: GT4 owners ( fuel pump relay ) Wed, 01 October 2003 04:58 Go to previous messageGo to next message
i thought these relays never bolted up anywhere
usually they are a push in fit in the fuse box area either drivers side or passenger side
the one u r thinkin og in the engine bay could be the 2 stage fuel pump relay which controls the voltage to the pump
CrAiGzEE
Re: GT4 owners ( fuel pump relay ) Wed, 01 October 2003 05:57 Go to previous messageGo to next message
yes sideshow u are correct, on the wiring diagram its still called a fuel pump relay
Classique71
Colac, Victoria
Re: GT4 owners ( fuel pump relay ) Wed, 01 October 2003 08:14 Go to previous messageGo to next message
is this the one you may want to tweak to run the 13.5v constant flow trick ?
If so - i can grab a pic of how this is done to the relay fusey thing in the engine bay ( its done on mine )
sideshow
Re: GT4 owners ( fuel pump relay ) Wed, 01 October 2003 09:52 Go to previous messageGo to next message
to run constant 13 volts just join the 2 wires that goto the heatsink resistor right next to the fuel pump control relay in yr engine bay
there will be a blue one and a blue/black one
Classique71
Colac, Victoria
Re: GT4 owners ( fuel pump relay ) Wed, 01 October 2003 09:58 Go to previous messageGo to next message
or i could just get off my arse and take a picture Wink
CS3086
Denmark
Re: GT4 owners ( fuel pump relay ) Thu, 02 October 2003 19:14 Go to previous messageGo to next message
Can you feel any power gain with this mod.?
Jacob.
Denmark.
Classique71
Colac, Victoria
Re: GT4 owners ( fuel pump relay ) Fri, 03 October 2003 08:55 Go to previous message
cant tell you if it makes a difference or not - ive had it all the time on my car
all i know is it can run a little rich and blow some fuely black smoke when you give it a boot
I still have the other fuse - so i should give it a go one day to see if it does help at all
Previous Topic:Who Knows of any other forums that sell parts
Next Topic:Clutch master cylinder AW11
Current Time: Fri Nov 20 07:51:21 UTC 2026
Total time taken to generate the page: 0.0053210258483887 seconds
