Toymods » Tech & Conversions » 18RC Engine question
GIN51E
Berowra-Sydney
18RC Engine question Wed, 17 July 2002 13:23 Go to next message
If you know in detail anything about the 18 RC engine then you may be helpful, changed the sump gasket last sunday a process i don't plan on doing again unless i have a hoist in my garage! anyway i found in the bottom of the sump two pieces of metal, which i traced back to be missing from the 3rd and 4th piston. now if you know how these pistons look then you would know that they are like all pistons round at the bottom except on two sides of the piston the bottom extends a little bit lower which kinda looks like two flat dags hanging off each side of the piston now on the 3rd and 4th piston these dags have broken off, has anyone heard of this happening before and what does this mean for the engine what do these parts do? they could have broken off anytime in the last 7 or so years since the gasket was changed last time and there are no signs of stress, dints or heat fatigue on the broken off parts so who knows why and how they broke off but it would be interesting to know if anyone has had this problem before? (Engine still runs perfectly fine with no vibrations, knocking noises or so forth) so who knows what these bits do.
Bugman
Re: 18RC Engine question Wed, 17 July 2002 13:41 Go to previous messageGo to next message
could have been left inside from the last rebuild, cos I remmeber nearly leaving a screw driver inside a sump of a suzuki until I could find it to do up the srews to hold it on Rolling
Allan
Re: 18RC Engine question Wed, 17 July 2002 14:00 Go to previous messageGo to next message
never seen an 18r go like that something majoryly wrong there!
Allan
Re: 18RC Engine question Thu, 18 July 2002 08:06 Go to previous messageGo to next message
I say dump the bits and forget them Very Happy
Celica_RA40
Re: 18RC Engine question Thu, 18 July 2002 10:56 Go to previous messageGo to next message
it could be that it is caused by the piston fit in the bores being too loose and getting piston slap where the piston slaps up agians tthe inside of the bore. if i were you i would junk it and buy a second hand one for about $300 if the piston to bore clearance is to great if you wanted it to run properly again it would need to bored oversize and oversize pistons and rings fitted.
the part you are talking about that has broken off is the piston skirt.
GIN51E
Berowra-Sydney
Re: 18RC Engine question Thu, 18 July 2002 22:05 Go to previous messageGo to next message
its just the engine runs as if nothing happened and all the cylinders have a compression of around 180psi so i can't think theres so much of a problem except at the end of the year i'll be driving down to Tassie (via a ferry of course) so the test will be how it handles that its been down to melbourne before and took it in its stride except on the way back while cruising at night i was sitting on about 160km/h for about 5min and then looked in my mirror and saw sparks skatering all over the road and when you see that it scares the shit of ya. pulled over couldn't find anything wrong with the engine oil preassure was fine so forth then i looked at the exhaust and it was glowing red, so i avoid drivng at high speeds for to long a time now. Smile
RA23_Sean
Western Sydney
Re: 18RC Engine question Fri, 19 July 2002 09:14 Go to previous messageGo to next message
What you describe sounds familiar to what I found the sump of my 18R-G (18R-C bottom end). What colour are these little bits? Greyish?
I assumed the bits I found were from the timing case as one of the cam pins had fallen out and ended up in the sump. This was found a week after I had got the motor going after a rebuild.
And yeah, pulling the sump off is an absolute bastard on an 18R Celica.
GIN51E
Berowra-Sydney
Re: 18RC Engine question Sat, 20 July 2002 07:05 Go to previous messageGo to next message
on one side of the bits there is kind of a lip where on the other side its nice and shiny, i confirmed they were off the pistons as i got under with a torch and could see the bottom of the pistons and saw where they had come from. if i end up getting a new scanner i'll scan them and put them up on here.
bexi
Re: 18RC Engine question Sat, 20 July 2002 08:19 Go to previous messageGo to next message
hey man
if you need a new engine, i can get u one. my mate has a spare one 4 prolly 150 bucks. nothing wrong with it... he jus pulled it out coz he put an 18rg in.
GIN51E
Berowra-Sydney
Re: 18RC Engine question Sat, 20 July 2002 09:43 Go to previous message
nah mate engine still runs just fine no loss of power no funny sounds or viabrations all thats wrong is its missing two little bits of metal that should be in the engine but there in my ceter console instead. and this engine was $500 so i plan on keeping it for a very long time but thanks for the offer anyway
Previous Topic:ARP head bolts: 7m into 5m ??
Next Topic:what have i got?
Current Time: Sun Oct 25 17:04:40 UTC 2026
Total time taken to generate the page: 0.11268091201782 seconds
