Toymods » Tech & Conversions » RWD 4AGE
79rollaboy
NSW Engadine
RWD 4AGE Wed, 01 October 2003 06:55 Go to next message
Im thinking about what to do with my car, cant decide plus my dads a tightarse so that doesnt help.
How much am i looking at for a RWD 4AGE and anything necesary to hook it up?
gtman
Re: RWD 4AGE Wed, 01 October 2003 07:29 Go to previous messageGo to next message
if your dad's a tightarse, get a job Twisted Evil
is he tight as in, won't give money for a conversion, I don't blame him. My old man would never give me jack Razz If he's tight as in for space to doing a conversion, then I can sympathise with that, as there isn't much space at my house to have a car stripped down and converted easily without some lowlife off the street flogging off with things Sad
79rollaboy
NSW Engadine
Re: RWD 4AGE Wed, 01 October 2003 07:32 Go to previous messageGo to next message
i have a job thankyou very much
no its just like "your not putting one of those engines in your car" i think he has techno fear anything with more than air and fuel to run it is not cool with him. weve got his wrecked VL commodore out the front that hes workin on. so weve got like 4 cars out the front.
do you know anything about 4age's?
[Updated on: Wed, 01 October 2003 07:33]
gtman
Re: RWD 4AGE Wed, 01 October 2003 07:40 Go to previous messageGo to next message
haha, that's cool then. I can somewhat relate to that. My mum questions me as to why I want to put a TT 6 into my celica, let alone when I'll be wanting to put a TT 8 into my other celica Very Happy "you'll never be able to use it on the road!" etc etc Laughing
unfortunately I don't know anything about 4age's. I'm trying to learn as much as I can about the engine I have in my car and the one's I want to put in first before I go into other engines Very Happy The 4AGE rwd conversion is a popular one tho I understand, so I'm sure there's heaps of info under search. you're lucky too, as 4age is more then 2 characters long, unlike 1G, so the search engine won't kick you out (hint to whoever is fixing the search engine to fix plz Very Happy )
79rollaboy
NSW Engadine
Re: RWD 4AGE Wed, 01 October 2003 07:43 Go to previous messageGo to next message
yeh the bloody search engine, KE and 4K really shits me
gtman
Re: RWD 4AGE Wed, 01 October 2003 07:44 Go to previous messageGo to next message
I figured out the code to fix it, its now in the hands of the forum honcho's Smile
79rollaboy
NSW Engadine
Re: RWD 4AGE Wed, 01 October 2003 07:45 Go to previous messageGo to next message
hey what happened to the 4age you guys have hijacked the thread a little Laughing
gtman
Re: RWD 4AGE Wed, 01 October 2003 07:58 Go to previous messageGo to next message
you guys? it was only me and you Laughing
ok, did a search on the forums and came across these two links
http://forums.toymods.org.au/index.php?t=msg&t h=5174
http://home.clear.net.nz/pages/phil.bradshaw/modif ications.htm
hope they help Smile
79rollaboy
NSW Engadine
Re: RWD 4AGE Wed, 01 October 2003 08:00 Go to previous messageGo to next message
there was another guy...
anyway i'll have a look
79rollaboy
NSW Engadine
Re: RWD 4AGE Wed, 01 October 2003 08:11 Go to previous messageGo to next message
no there was no other guy, oh wait my medications kicked in now Rolling Eyes
GZE-STYLE
Camden
Re: RWD 4AGE Wed, 01 October 2003 09:18 Go to previous messageGo to next message
I was planning on doing a gze conversion in a KE30/55. You will need to convert your clutch to hydraulic, i assume you use the parts out of a TA22 celica,brake pedal etc. You would also mod the engine mounts, i assume its pretty straight forward.
[Updated on: Wed, 01 October 2003 09:18]
79rollaboy
NSW Engadine
Re: RWD 4AGE Wed, 01 October 2003 10:31 Go to previous messageGo to next message
that second site sort of laid it out for me.
a front cut sprinter would be all i need.
Steve-AE86
Ademelaide, SA
Re: RWD 4AGE Wed, 01 October 2003 10:45 Go to previous messageGo to next message
ahem....
well, having done this conversion many times, i can tell you that it is one of the easiest to do....
first up. the 4A-GE will bolt in using the normal engine mounts found on a RWD 4A engine. the only problem is, it will be solid mounted, meaning no engine mount rubbers...you CAN fit one piece of rubber, about 3mm thick, on each side, but it will be tight.
OR... you can fabricate mounts which bolt to the engine block, that use the standard sprinter rubbers. i have a set of fabricated mounts if you want to buy them from me, but it will set you back $75 plus postage....
the gearbox crossmember to use is the KE30/55 corolla one, but you need to spin it around, so the left hand side is on the right of the car.
you will need to get a tailshaft made up to suit, also.
the easiest thing to do for a radiator, is to use yours, if it is in ok condition. it has more than enough cooling capacity. but you will need to get it modified, so that both outlets are on the drivers side. this should cost around $20 at any radiator shop.
that's the basic mechanicals out of the way....that should get you started..
79rollaboy
NSW Engadine
Re: RWD 4AGE Wed, 01 October 2003 11:38 Go to previous messageGo to next message
now i just need to buy one
SLY16V
camden
Re: RWD 4AGE Thu, 02 October 2003 07:13 Go to previous messageGo to next message
hey, umm my mate is selling his 4age, but it isnt a rwd version.its a aw11 mr2 motor with 125000k's on it all sensors,uncut wiring loom and ecu...so its complete, i know your probably thinking that its gay cause its fwd but i have already does this conversion and i found it piss easy, all you need is a rwd intake manifold which i picked up from just jap in lansvale(ph.97542666)for $75,rwd exhaust manifold or you can get a set of extractors made by liverpool exhaust for $275 you can purchase these from stuart wilkins rally at mulgrave (not sure on the ph number but wouldnt be hard to find), and you just modify the fwd water pump a little and you set...umm i forgot my mate wants $650 for the motor above with everything to run it...so its your decision dude,
cheers mate
79rollaboy
NSW Engadine
Re: RWD 4AGE Mon, 06 October 2003 07:15 Go to previous messageGo to next message
sounds awesome but i really dont have the money. what about my gearbox can i use my normal one??
SLY16V
camden
Re: RWD 4AGE Mon, 06 October 2003 08:59 Go to previous message
nah dude you will need a t50 gearbox out of a sprinter or ae71 corolla...
Previous Topic:Trueno Front End to an Aus spec 86
Next Topic:IG-GTE's performance
Current Time: Sat Oct 24 19:44:07 UTC 2026
Total time taken to generate the page: 0.0060269832611084 seconds
