Toymods » Tech & Conversions » Car won't stay on, mechanical ignition problem?
gtman
icon4.gif  Car won't stay on, mechanical ignition problem? Wed, 01 October 2003 12:41 Go to next message
Coming home today, car stops all of a sudden. First thing that goes through my head is the alternator has died again, but all the electrics are fine and there was no charge light on. I try to start, it kicks over, then dies. Same again, same again. Then I realise I can keep it going by holding the key between On and Start, making sure the start moter doesn't tick over and fry itself ofc. I managed to get home like that, thank goodness it was only 5mins and not 50, as my thumb was shagged! Wouldn't think there was that much resistence there Razz
So my question is this, does this sound like just a problem with the ignition, or should I be looking somewhere else? I had to go out straight after getting home and its too dark now. I'll hafta wait till saturday to look at it damnit Sad
V8_MA61
Re: Car won't stay on, mechanical ignition problem? Wed, 01 October 2003 12:45 Go to previous messageGo to next message
depending which car is this?
could be computer???
Fuel ignition system?
gtman
Re: Car won't stay on, mechanical ignition problem? Wed, 01 October 2003 13:00 Go to previous messageGo to next message
18r-c ra23
V8_MA61
Re: Car won't stay on, mechanical ignition problem? Wed, 01 October 2003 13:06 Go to previous messageGo to next message
thatd have to be as you said, in the fuel/ ignition system.
Mr DOHC
Re: Car won't stay on, mechanical ignition problem? Wed, 01 October 2003 13:08 Go to previous messageGo to next message
was it trying to fire, i.e. actually starting then stopping while "driving home", or was it free spinning with only the compression slowing it down
gtman
Re: Car won't stay on, mechanical ignition problem? Wed, 01 October 2003 13:11 Go to previous messageGo to next message
it fired and kept going if I held it in like I said, I managed to drive it home like that no problem, cept for a few times when my hand was so sore I slipped abit, but turned it abit more and off it went again. It's like On is now Acc, and On is situated halfway to Start, if that makes any sense. I'll be pulling the ignition out when I get the chance and give it a good look.
boudan
Re: Car won't stay on, mechanical ignition problem? Wed, 01 October 2003 14:29 Go to previous messageGo to next message
Laughing .
sorry couldnt help myself...
perhaps you hit the kill switch...
i only found it funny as its more than likely something id do !
gtman
Re: Car won't stay on, mechanical ignition problem? Wed, 01 October 2003 16:04 Go to previous messageGo to next message
no kill switch on this car, and if I did, it wouldn't even start Smile
IRA11Y
Club Member
Re: Car won't stay on, mechanical ignition problem? Wed, 01 October 2003 21:36 Go to previous messageGo to next message
its most likely the ignition barrel (key) at the back of the key is the contact points for ignition, sometimes older cars get dry solder joints and fail, that is where id be looking Smile
Mr DOHC
Re: Car won't stay on, mechanical ignition problem? Wed, 01 October 2003 23:52 Go to previous messageGo to next message
maybe i heard wrong, so u dont drive the car home via the starter?????????????????????
Re: Car won't stay on, mechanical ignition problem? Thu, 02 October 2003 00:03 Go to previous messageGo to next message
IRA11Y wrote on Thu, 02 October 2003 07:36
soudns EXACTLY like that... when you turn to start, coil power comes off a different circuit (ie the starter circuit, and often has ballast resistor switched out.. if you have one). when you turn back to 'on' the coil power goes thru switch, to ballast res, to coil..
i',m guessing that either your switch is farked (you can test easily by jumpering from battery +ve to coil/ballast resistor +ve, and startign car. you'll have to take off the jumper to stop the car tho!!!! be careful!!!
oh, or you could turn key to start and either put multimeter, or globe, from coil +ve to ground... if no voltage put test thing to the ballast resistor +ve.
it's gonna either be dead ignition switch, or dead ballast resistor
Pumpkin
Toymods Board Member
Re: Car won't stay on, mechanical ignition problem? Thu, 02 October 2003 01:51 Go to previous messageGo to next message
I agree with oldcorolla.. Same thing happened on my car.. It will be the Ballast resister...
gtman
Re: Car won't stay on, mechanical ignition problem? Thu, 02 October 2003 01:56 Go to previous messageGo to next message
Thanks Michael and Stewart, I'll get testing on the weekend with what you suggested. Phil, I meant so I didn't drive home with the starter motor ticking over, which would have been a few hundred dollars down the toilet in 5 minutes Smile I learnt from my last time with that when the key was getting stuck on Start without me knowing it Smile
Jason
Re: Car won't stay on, mechanical ignition problem? Thu, 02 October 2003 02:20 Go to previous messageGo to next message
Ballest resistor on the coil and probably your starter after driving it home like that Crying or Very Sad
I had this problem in one of my rollas.
gtman
Re: Car won't stay on, mechanical ignition problem? Thu, 02 October 2003 02:41 Go to previous messageGo to next message
but the start wasn't ticking over on the drive home, so I don't think it would be damaged Confused
faulksy
Re: Car won't stay on, mechanical ignition problem? Thu, 02 October 2003 05:33 Go to previous messageGo to next message
Jason wrote on Thu, 02 October 2003 11:50
i agree definitely sounds like the ballest resistor. its usually a creamy/white rectangulor block next to or connected to the coil. cost around 5-10 dollars. in the mean time it can be fixed by joining the + and - terminals together with a piece of wire
coronamark2
Re: Car won't stay on, mechanical ignition problem? Thu, 02 October 2003 05:40 Go to previous messageGo to next message
sam thing happend to mine but i couldnt start the car it couldnt get nay spark but i could start it if i bridged the wire on it.
i got a new one for $5 Very Happy
its all sweet, i allready have a new alternator,starter motor,coil,battery,voltage regulator so i have no worries that my car wont start Smile
fingers
Darwin
Re: Car won't stay on, mechanical ignition problem? Thu, 02 October 2003 05:41 Go to previous messageGo to next message
Definately agree with the majority on this one.
Had exactly the same problem with my corona. As soon as you let the key go it stop. Replaced the ballast resistor and all was good. Smile
crazedrt104
Darwin
Re: Car won't stay on, mechanical ignition problem? Thu, 02 October 2003 06:12 Go to previous messageGo to next message
yup...id be puttin my money on the ceramic ballast resistor
gtman
Re: Car won't stay on, mechanical ignition problem? Thu, 02 October 2003 10:34 Go to previous messageGo to next message
ok I just swapped the resistor from my black celica onto my silver one, and no joy, did the same thing. Looking at the thing, is there any visible way of telling if its dead? Also, one my silver celica there was a + but on the other resistor nothing, and they were mounted differently, so is there a way of telling which way is which?
cheers for the help to silly problem Sad
Jason
Re: Car won't stay on, mechanical ignition problem? Thu, 02 October 2003 23:37 Go to previous messageGo to next message
Check the resistance. The problem is that they corrode and break down.
Re: Car won't stay on, mechanical ignition problem? Fri, 03 October 2003 00:15 Go to previous messageGo to next message
if changing the resistor made no diference, then have you checked the ignition switch??
use a multimeter, or a light globe, connect oen side to ground of battery. turn the key to 'on' then put put other side of globe/multimeter to the coil +ve, and both sides of the ballast resistor. then get someone (you trust Wink ) to hold the key in the same position that got you home, and do the same test.
if the ballast resistor is fine, then your ignition switch is farked. have had this happen to a couple of my rollas, btu then they are 30+ years old Wink
good luck,
gtman wrote on Thu, 02 October 2003 20:34
crazedrt104
Darwin
Re: Car won't stay on, mechanical ignition problem? Fri, 03 October 2003 05:00 Go to previous messageGo to next message
check the cables going onto the ballast resistor...i had a dodgy cable that took me days to figure out
gtman
Re: Car won't stay on, mechanical ignition problem? Sat, 04 October 2003 05:11 Go to previous messageGo to next message
I love and hate simple solutions. I love them cause they are, well, simple, but I hate them cause you run around looking for all kinds of electrical problems when the thing wrong is a blown fuse Embarassed
Thanks for your hlep guys, I'll go back under my rock Smile
gtman
Re: Car won't stay on, mechanical ignition problem? Thu, 23 October 2003 07:26 Go to previous messageGo to next message
as a finale to this problem, it did end up being the ballast resister. It must have gone and caused the fuse to blow. I followed your instructions and put the resister from my other car on my silver one, and there was no joy, but then I noticed the fuse, replaced it, and problem was gone, but kept the resister from my black car on there. Today I swapped them back cause the black one is off getting an overhaul of the entire brake system (540 bucks, ouch!), and when I started the silver one, same thing happened again, and a fuse was blown. So off to autopro, picked up a new resister, and everyone is happy again, except my wallat having to pay for those brakes Confused
coronamark2
Re: Car won't stay on, mechanical ignition problem? Thu, 23 October 2003 07:49 Go to previous messageGo to next message
who why how? ($540)
I hope that was for new discs, pads, calliper recon, bearing ,seals,drums ,shoes ,brake lines and everything else brake related.
i got a new disks (front) $75 pair new pads (front $60) and bearing/seals for $50. i couldve got new drum shoes for $20 but couldnt be fkd
gtman
Re: Car won't stay on, mechanical ignition problem? Fri, 24 October 2003 05:41 Go to previous message
Perth brake clutch exhaust in kenwick. Yeah, it is pretty much everything getting an overhaul, new discs, recon the calipers, new handbrakes lines etc etc etc. They think my master cylinder has a problem too cause its not holding pressure on the pedal, which if true I'm going to be pissed cause I had it recon'd about 7 months ago when I lost all pedal feel Mad
Previous Topic:inductive speed sensor .. how they work?
Next Topic:Air Condition in old car?
Current Time: Fri Nov 20 06:14:09 UTC 2026
Total time taken to generate the page: 0.010514974594116 seconds
