Toymods » Tech & Conversions » Brake re-sealing...
UZZ31
Brake re-sealing... Thu, 02 October 2003 10:06 Go to next message
Greets all!
I have a set of JZZ30 Soarer BIGer brakes Very Happy Very Happy to go on my UZZ31 and am about to re-seal them with the relevant Toyota kit, both fronts and back. In the kit there is a little satchel of pink grease - is that to be used within the cylinder or on the sliders or both? Do I need to use brake fluid anywhere in the re-assembly process?
Also, do I need to be worried about very minor scratches on the pistons??????
Thanks Y'all!!
AE.
IRA11Y
Club Member
Re: Brake re-sealing... Thu, 02 October 2003 10:34 Go to previous messageGo to next message
use the grease inside the caliper slides you dont need much, you can also use a very small amount on the piston to help it go in easier
Allan
Re: Brake re-sealing... Fri, 03 October 2003 12:49 Go to previous messageGo to next message
UZZ31 wrote on Thu, 02 October 2003 20:06
if you can feel it (or any pitts) with your finger nail? yes you do have to worry about it, you can get new pistons or get them stainless steel sleaved
Allan
UZZ31
Re: Brake re-sealing... Sat, 04 October 2003 12:32 Go to previous messageGo to next message
Thanks to both you guys - I got to thinking I can more than likely use the pistons out of the current calipers in the car - I beleive that the rear brakes are the same in both models - just that the disk is bigger in the JZZ* models.
IRA11Y
Club Member
Re: Brake re-sealing... Sun, 05 October 2003 00:33 Go to previous message
if the discs are bigger you will generally find the caliper and are slightly wider, sometimes ( like with the sprinter discs ) its hard to see until you put a ruler over them as they look identical.
Previous Topic:Standard MX83 auto-box - How strong?
Next Topic:air in brakes
Current Time: Mon Nov 2 06:08:12 UTC 2026
Total time taken to generate the page: 0.0095641613006592 seconds
